Did the Lincoln screen swap
BigBlue20
New Jersey
2020 Explorer St
I think I’m gonna go ahead and do this swap. I lover everything about it except for the printed bottom trim people are using. I’ll send the screen to my friends at MTI to fab something more oem looking.
BigBlue20
New Jersey
2020 Explorer St
The bottom piece fits good, I mean we are doing a retro fit of something that isn’t supposed to go there is never going to be 100%
Something like this? When you turn off the car this is what it shows. Now I have a Ford Explorer ST/ Navigator
I think livingitup has a file to fix the l8ncoln thing
Did you try resetting the splash screen in forscan
That set up looks perfect. Great height and everything
Have a parts list you can share
Prices seem to be all over for the screen
And mounts
Have you tried to change the Theme?
Push the fast forward button Button (Steering Wheel) and fast forward button Button on the radio for 3 sec.
Test Tone will play.
Push Testing Setting.
You can select about 20 Theme from that menu.
BigBlue20
New Jersey
2020 Explorer St
I haven’t yet
BigBlue20
New Jersey
2020 Explorer St
When you make the changes in forscan and connect the Lincoln screen it boots up to the ST logo like it normally would do, went it turns off it says Navigator.
Well thst is strange...must still have lincoln software version in the screen
Let me ask the boss .
He does modules
That’s the one I hate. I guarantee mine will look like it came there….I won’t accept anything less.
BigBlue20
New Jersey
2020 Explorer St
I think the only way to make it look like it came like that from factory would be continuing the chrome bezel all around
Jessup, MD, USA
Yeah I just bit the bullet on this one. Ordered from Tasca. I ordered quite a bit over the years when my business had a bunch of Ford trucks. Under a grand delivered….hopefully
How much was it at Tasca? I am on a little family trip and happened to drive past Tasca in Rhode Island. I had no idea it was here.
BigBlue20
New Jersey
2020 Explorer St
I tried these one and all it does is turns the screen black out then it comes back to normal after you turn off an on the ignition switch.
It was like $960 tax and shipping for the six Ford items needed. Nothing in stock though.
I have mine in the ford parts shopping cart
Cable and screen
I assume the screen is complete with bezel surround...
Couldn't find a mount bracket..
Or does it come with screen
Irc sub total is right at 900 and some change. Minus my gazillion pass points
It will be less
BigBlue20
New Jersey
2020 Explorer St
Cable and screen
It will be less
My total on ford parts was $1300 and change so I saved about $400. I only had $100 in points. Again this for six parts.
LC5Z10D885UE
LB5Z7813546AC
LC5Z78042A82AA
LB5Z78046B46AA
LB5Z9901 8B40CA
LB5Z78042A82AB
BigBlue20
New Jersey
2020 Explorer St
LC5Z10D885UE
LB5Z7813546AC
LC5Z78042A82AA
LB5Z78046B46AA
LB5Z9901 8B40CA
LB5Z78042A82AB
I bought the screen, back screen cover ,8 inch screen vents used from eBay. The bottom cover piece for the screen from Etsy all for around $470. I opted for keeping the original bottom piece bellow the screen ( part #LB5Z7813546AC ) and just cutting a small piece of rubber pad, which saved me around $150 that it would cost from ford parts.
Instrument Panel Bezel Vent Air Louvre Part#:LB5Z99018B40CA
why do we need this bezel for ac vents ?
all those part numbers above, THANKS
cart is now 1157..not bad imo for all the piece parts
i thought the mount was in there, i see i can re purpose the current mount
i added an attachment of cart if anyone wants to cut and paste it
i used a generic page,
