10 vs 14 speaker B&O on 2025 - worth it?
WWLD
Portland, ME
2022 Audi Q5
First time post. Looking to buy new ST with either the standard 10 speaker B&O system or as part of the 'Sight and Sound' package (with panoramic roof) that has 14 speakers.
Is the 14 speaker version any better? Also, how much weight difference with the big glass roof?
Any inputs? thx
Illinois
I just picked up my 2025 ST 2 weeks ago. I wondered the same thing. I asked to listen to both systems, one on an Active line and the ST I purchased. It was a night and day difference. The sound quality fill and over all power difference was noticed quickly not only by myself but my wife also. You will want the 14 once you hear the difference. Go to the dealer and ask to test drive an active to hear the difference.
Canby, OR
Any inputs? thx
Welcome to the forum. The 14 speaker is better than the 10 speaker but it's still just Ford speakers with the B&O logo. The little 8"subwoofer doesn't do it justice and the bass cuts out around volume level 15. If you just like to have music it's fine for the average person. For me though, I replaced everything with a real system. But I appreciate good quality sound.
DesertPA
PA
Any inputs? thx
I don't know how the 2 systems compare, but I think the 14 speaker system is ok. The sound and imaging through the mid-range is better than I expected, once I turned the surround sound off. However, the bass is worse than I expected --- over boosted and pretty messy. It helped a little to turn the bass down a bit, but the bass still isn't very satisfying. Still, the overall sound is good enough to be enjoyable to my ears.
I don't know how much the weight sunroof adds, but I can't see it how it would make enough difference to notice in most circumstances.
Chairborne Ranger
I'm curious how Ford can market the vehicle as having a "B&O" audio system but not use B&O speakers; wouldn't that be false advertising? Since you swapped out your speakers I'm sure you could see they were not what is being sold to the customer which is pretty disappointing. I now wonder about all of the various Bose systems I've had in previous vehicles and if they were really Bose or not?
W
WWLD
Portland, ME
2022 Audi Q5
Thanks for the update. Sounds like good advice!
Because B&O was involved with speaker location and final tuning. It’s pretty common across various mfg’s.
W
WWLD
Portland, ME
2022 Audi Q5
I looked on a virtual window sticker to try and figure out how much extra the panoramic roof adds to the weight. I did not see it listed but maybe it is listed on the vehicle door panel where the tire pressures are listed? Anyway...
If the 14 speaker system was not special, I would probably skip the upgrade package, and upgrade the speakers with the $3000 savings....while saving some vehicle weight?
Canby, OR
Too bad you can’t get the 14 speaker system without the sunroof. With the 10 speaker you lose one in the front doors. You don’t really need a 3-way but it’s nice when you do.
Gluestick
Nashville TN
I just picked up my ST a week ago, and its got the Sun & Sound package so I've got the 14-speaker setup, but I only see two speakers in the front doors. A big 6x9 lookin' guy down low and the ~3" behind the silver grille by the handle. I've had the door panels off to begin sound deadening and that was all that's there.
KCM
Nebraska
For reference, here are links to info on the B&O system in the 2020 to 2024 model years:
Ford Explorer
B_O_2022_Explorer_English_US.pdf
I'm guessing they moved the speakers from the doors to the "fabric-wrapped acoustic sound bar" on the dash.
Gluestick
Nashville TN
I think that matches what my ears are telling me.
My 2026 came without Sun&Sound so I can only comment on the 10 speaker B&O. Compared to the stock 14 speaker in my 2020, it sounds better. I think the front tweeter location has much to do with that. After adding a subwoofer, I think many will be pleased with the system.
These threads are telling me that the newer ST B&O systems sound better than the old. I'm very happy with my 2025 after setting the fade way back to reduce front door bass and get second row mids and highs involved (and also rear sub can be heard in the front row). I also set mids down a bit to get even more clarity at high volumes. I think it's a decent factory system after adjustments.
Also, you mentioned subwoofer... I added a ported sub box directly to the factory sub amp matching the dual voicecoil setup, and the bass is now powerful and deep. It's honestly much better than I thought it could be... I estimate about 200 watts solid on all frequencies. No electrical wiring, so it's very easy. Hope you are happy with yours now!
