Leaking oil?
I’m at 43k miles, it seems as this is a common thing, that should be covered.
It should be under powertrain warranty like my 2 front CV axle replacements a few weeks ago at 38K miles.
Burlington, ON, Canada
I was at 98,000 km, which is outside of the bumper to bumper warranty, but inside the powertrain warranty, and the service advisor told me it was covered under the powertrain warranty. Zero $.
A fellow member reported that their AWD module went out and the dealer said it was NOT covered under Powertrain warranty. Surprisingly, it is not listed as a covered component. The similar speed sensor might not be covered under Powertrain either. Either way, it might be good to run a diagnostic to see what codes come up. The speed sensor malfunction has a specific code when you run Forscan. The speed sensor is an easy DIY. The AWD module might need Forscan loading AsBuilt configuration after replacement--not sure but may not be an easy DIY.
https://www.ford.com/support/how-tos/search/powertrain.warranty.coverage
Mentions PCM but not any other module.
I would love to understand how they try to justify having a powertrain warranty that does not cover the system that controls a big part of the powertrain.
Kryuenger
Kryuenger
Thousand Oaks, CA, USA
Thread Starter #25
Service advisor said — there’s a list of parts that are covered, and the part number for the module doesn’t populate
Kryuenger
Kryuenger
Thread Starter #27
Well, Ford Corp came through and cover majority of the cost. Dealer quote - $870 (kind of ridiculous), after Ford Corp $170. Today, I received a call from Ford Corp giving me an additional 3yr/36,009 extended warranty for free. I guess I’m keeping my Explorer now
Toronto, ON, Canada
Axle hub actuator leak on the drivers side.
Does anyone know the part # to replace this driver side actuator or is it a ring/seal/module that needs replacing? Ford says they don't recognize the name or photo.
Tks.
Toronto, ON, Canada
#29
Does anyone know if we can get a better oil pan than the stock plastic one on the ST?
#30
Tks.
Ford Boss has 2 or 3 videos discussing the problem.
An O-ring is the problem. Last I heard, the replacement actuators he put in are leaking after a time too! Sounds like this is going tobe a widespread problem.
How you fix it depends on your warranty status. It is a b$"#*% to remove. Moreover, they changed the design so replacement would require reprogramming the AWD module if you have a MY2020 or early MY2021.
Me? I was past powertrain warranty and no ESP. I suspected the leak was a low pressure oil leak. I cleaned the area with brake cleaner (engine cold) then applied quick setting gasket sealer with my finger. The top surface you don't have access to, so I cleaned it again and sprayed Permatex leak sealer spray with straw (multiple coats). So far so good.
Toronto, ON, Canada
#31
Wow...this sucks. So you're suggesting to avoid replacing the o-ring and actuator as it clearly doesn't last long (past 10k miles) and simply "fill" the area with gasket sealer and permatex leak sealer spray along the top yeah?!
What about reprogramming the AWD module..is there a point?
Curious question as I'm not mechanically inclined and feel rather lost at this point. What if I just left it the way it is leaking oil (it drips rather than poors oil). What would happen? I'd obviously continue with regular oil changes to maintain oil levels.
Thoughts anyone?
sdreefer619
SAN DIEGO
2023 EXPLORER ST
#32
MORE THEN LIKELY ITS THE DRIVE UNIT NOT THE OIL PAN I WOULD DOUBLE CHECK WHERE THE FRONT DIFF GOES THROUGH THE OIL PAN
Toronto, ON, Canada
#33
Well I opted to go with:
Let's see what happens.
#34
Finger's crossed. I recommend you source some Motorcraft 75W-140 Synthetic Rear Axle Lubricant to top off the front differential (holds 0.6 qt).
sdreefer619
SAN DIEGO
2023 EXPLORER ST
#35
JUST TAKE THE CAR IN AND HAVE THEM FIX IT RIGHT. PEOPLE LIKE YOU MAKE TECH LIVES HARDER LOL
sdreefer619
SAN DIEGO
2023 EXPLORER ST
#37
WELL WILL YOU LOOK AT THAT I WAS RIGHT ONCE AGAIN.
Careful there, don't break your arm patting yourself on the back.
E-Fortes
Pembroke Pines, FL, USA
#39
What’s the fix? Is it covered under warranty?
YES it's covered under warranty 5 Y / 60.000 M / I had the same problem with 41,000 miles and Ford covered everything, even a rental car for 5 weeks (waiting for parts).
I think the problem is due to the Axle seals not supporting the temperature of the Engine (Axle passes through the Oil Pan). Supposedly they upgraded the parts...
Best Regards
