Tpms relearn 2020 ford explorer st / black wheel
#61
Well hallelujah and praise the Lord! New sensors came in today and they all work! Finally!
Great news. You do seem to have a bad luck cloud following you. Not the first strange problem you have encountered.
#63
It's true! I have the worst luck!
Canby, OR
You're hillarious man! You just can't make this shit up! Ha-ha! Remind me to never get in your personal space!
Babooin
us
Ford Explorer Platinum 2020
#65
I assume the procedure for TMPS sensors is the same for explorer 2017 XLT or your ST.
Do you know what could be the issue with the following:
- I have 1 bad TMPS sensor which car detects even after swapping wheels front to rear;
- I bought 1 new sensor from Ford dealership who was using my VIN to make sure I got the right one (F2GZ-1A189-A);
- Before installing sensor to tire, I went to one shop and they tried to read the signal from sensor but failed;
- I went to dealership and exchange it to a new one, tried to relearn it using grey tool + retrain mode. I managed to do it for first 2 sensors but the third one which I am trying to replace I tried new one and it did not work.
I read other forums and someone suggest to use OBD tool + forscan to remove existing sensors and try from a scratch (I have FORScan ELM327 and some old version of app itself)
Went today to dealer and the answer was very easy. There is no way to check if ford tpms sensor is ok or not until you actually put it to the tire. The presure itself turning it on.
Jessup, MD, USA
#66
I'm reading through this thread as my driver front sensor went out over the weekend.
I got this 315MHZ sensor installed: https://a.co/d/im9xIBI
I drove a few miles (less than 10) still hasn't come up.
I also tried the manual relearn with the clicker tool. I got it to beep for the other wheels, but not the new one. Chatgpt says I got the wrong one and need to get this one: https://a.co/d/dLRrSMG
Should I try pulling the battery next? Or just drive some more?
I have forscan, is there anything there I can do?
It seems that maybe all 315mhz sensors are not the same, and maybe there are some other communication protocols to be taken into account.
Sounds like you got a bad sensor. And any 315mhz sensor will work.
#68
I ordered a set of OEM sensors off eBay and none of them worked. They refunded my money. I got a set off Amazon and the same thing! Then I ordered a set from TPMSDirect.com and they all worked fine. Of course, I have the worst luck.
Jessup, MD, USA
#69
I have a set of Amazon TPMS ready to replace all 4. Is it possible to test them out before I mount them on my tires using the relearn process?
#70
Yep. Just put a sensor on each tire and go around with the tool.
Jessup, MD, USA
#71
I just tried with the Amazon sensor, I tried all 4. I held them next to the tire and inside the wheel while clicking the relearn tool, no beeps.
I'm wondering if I should just go with a Motorcraft TPMS instead.
23 Explorer ST
I personally would stick with the OEM.
Amazon and eBay have a lot of “fake” OEM products.
2023 Explorer ST, Rapid Red
#73
I’m telling you, check out TPMSDirect.com. The first sensors I bought off eBay were OEM and didn’t work! The sensors from TPMSDirect are all tested before shipping. I bought the metal stems to match my rims and they worked perfect. Bought a second set for my Ranger and they didn’t work. Contacted them and they said it’s because the Ranger uses a different protocol. They sent me a shipping label to send them back, programmed them and shipped them back. Worked fine after that. Very good customer service! You might pay a little more but they are guaranteed to work!
Jessup, MD, USA
#74
Which model did you go with?
Jessup, MD, USA
#76
Do I need to do anything special to get my car to recognize the new sensor? My front left OEM sensor died and I've had a tire pressure sensor fault light for the last 3 weeks.
I've been testing new sensors by going into relearn mode and using a clicker tool. So far, several sensors that I've tried do not get picked up, and even the ones currently on the car (that I know are working) often do not honk during the relearn.
