Tpms relearn 2020 ford explorer st / black wheel
#61
Well hallelujah and praise the Lord! New sensors came in today and they all work! Finally!
Great news. You do seem to have a bad luck cloud following you. Not the first strange problem you have encountered.
#63
It's true! I have the worst luck!
Canby, OR
You're hillarious man! You just can't make this shit up! Ha-ha! Remind me to never get in your personal space!
Babooin
us
Ford Explorer Platinum 2020
#65
I assume the procedure for TMPS sensors is the same for explorer 2017 XLT or your ST.
Do you know what could be the issue with the following:
- I have 1 bad TMPS sensor which car detects even after swapping wheels front to rear;
- I bought 1 new sensor from Ford dealership who was using my VIN to make sure I got the right one (F2GZ-1A189-A);
- Before installing sensor to tire, I went to one shop and they tried to read the signal from sensor but failed;
- I went to dealership and exchange it to a new one, tried to relearn it using grey tool + retrain mode. I managed to do it for first 2 sensors but the third one which I am trying to replace I tried new one and it did not work.
I read other forums and someone suggest to use OBD tool + forscan to remove existing sensors and try from a scratch (I have FORScan ELM327 and some old version of app itself)
Went today to dealer and the answer was very easy. There is no way to check if ford tpms sensor is ok or not until you actually put it to the tire. The presure itself turning it on.
