Leaking oil?
Tbishop
Kelowna, BC, Canada
Thanks for the quick advice and reply. Playing phone tag with their service advisor and will see what they come back with, and update the thread. Great to have this community as a resource for sure!
Buffalo, NY, USA
Just dropped my Explorer off at our Ford store for the exact same oil leak.
Will keep updating as I hear from them.
21 with 55k miles.
just had transfer case, front/rear diff service done about 1000 miles ago.
70K miles, leaking oil, but no codes. I've covered it in RTV to stave the flow.
Has anyone attempted to tackle this TSB themselves? I'm out of warranty and 7 hours for a $3.00 o-ring is a lot....
Youtube implies that if you undo the motor mount you can wiggle it enough to get the blocked bolt out of the way. I would like to know if this method actually works before I pull it apart in the garage and get into a bad place. I don't have a lift, so I will be working on the floor.
Every mechanic I've called has said this is a royal PITA and quoted me the full 7 hours. I can't believe there isn't a better way.
The sealant will last a while but not forever. I did the FADA delete TSB since I was already removing it, the parts are relatively cheap (intermediate shaft and new axle half shaft) and I have capability to use FDRS for flashing the AWD module. That FordBossMe video explains it and can confirm it is doable and not too difficult... about 3-4 hrs total including front diff oil refill and flashing. I used my long prybar to push the motor mount out of the way of the bolts.
The parts are pretty cheap and I can just pay ford to flash it. Seems silly to take it all apart and not replace the failure prone component. The suspension and CV work don't bother me at all. How hard was it to push the motor mount out of the way and back into place? That's my hangup on this whole job.
It's tricky but doable. You are basically pushing against the motor mount's own bushing which wants to return the mount to original position which blocks the bolts. I found it harder to reinstall the one blocked intermediate shaft bolt compared to removing it. I reused the bolts that held the FADA. It is also tricky to get the motor mount bolts back in alignment to tighten down. Tricky but doable. The FordBossMe video explains all you need to do...unfortunately, he doesn't do the process on a 3.0L but just explains it.
Alberta, Canada
Damn, i was hoping your seal was still lasting. Worth doing still (your external seal fix), over paying ford? Sadly BOTH of our 2020s are leaking...
External seal lasted 40k miles. the red sealant still held, the spray sealant for the area you can't reach is what gave out. Depending on how ling you keep the car and how often you check for leaks, DIY sealing is still an option. Unfortunately, a dealer will probably bill 8 hr just to replace that O-ring that can be done DIY in 2.
Alberta, Canada
What kind of sealant spray did you use / can you use? Having a hard time in Canada figuring out what is available and what I should be looking for. Thanks!
I used Permatex spray sealant after spraying area with brake cleaner. Several coats. pay attention to dry times and cure times
brian.sestokas
Memphis, TN
Do you have a picture of what it looks like after you did the spray? My warranty just ran up at the end of November before I could see everything starting to leak.
brian.sestokas
Memphis, TN
Has anyone had to do the half shaft seals out of warranty? Found that both of mine started leaking at some point between now and the last oil change. I do not have the ability to get this done in my driveway during the winter, but I need the vehicle running.
Just had this seal replaced under warranty on my 2023. 34K miles.
Had the vehicle in for service for an unrelated reason and in their inspection they found this. I think the last time i changed the leak, i may have seen the start of it and just assumed I had been a little messy the last time I drained the oil.
Looks like the O-ring was revised again. Part number N1MZ-4A015-C
One question. It was covered under warranty but I noticed coolant was listed on the invoice as parts used. Does the cooling system need to be drained to perform this job?
MIdwest
Thanks for the note on the new o-ring part number, I need to look at my receipt. As another data point, my dealer "charged" $400 to replace the o-ring. It was covered under my Gold extended warranty. I don't think there is any reason to involve coolant in this repair.
I don't think so either, but listed on the invoice right under the O-ring and some misc bolts and anti-seize is 4x VC-13-G antifreeze. No idea if that's gallons, quarts or ounces. I didn't catch it until home so didn't ask the dealer about it.
brian.sestokas
Memphis, TN
Thanks for the updated part number. I am going to have to order 2 of them since both the driver and passenger side are leaking. Got quotes from the dealership $3700 in labor alone to replace both seals. They are not willing to do the tsb since in their words " the codes are not present to warrant the tsb parts to be installed".
