Not sure if you’re like me but I hate the green light on the ignition button. It just stares at me!! I had to do something about it. They are SMD led diodes and are a pain to get to and change out. So I did a little hack.
Pop off the inner portion with a butter knife or similar tool and you will see the green and blue lights. You will need to slide the clear plastic piece that helps illuminate the green light out. Once you slide that out use something to cut the black plastic exposing the green led and help shine the blue throughout the entire opening. I used a pair of micro wire cutters
Before
After
Now take a tool that is sharp and scrap the top of the green light to burn it out or use something to cover it. (Black electrical tape if you plan on wanting the green light again). Now the blue bulb is the only light and matches the console and dash lights.
Finished in 5 mins
Searched eBay and found a solid red to get rid of the carbon so it doesn’t clash so much.
Plan to wrap the outer ring in satin black.
This mod is not for everyone but wanted to share.
@UNBROKEN can’t be the only one with ideas!! [emoji6]
