Leaking oil?
Toronto, ON, Canada
Just had my 2020 ST (65k km) in for an oil leak. The dealership came back with front differential intermediate shaft oil seal. They replaced the base part with 4A015. Took them from about 4hrs to fix.
Total cost would of put me out of pocket $1,200+ but was covered under my ESP warranty.
Thanks to this thread as it seems to be a common issue with these vehicles.
Massachusetts
2023 ST
I was in for a different warranty issue (HVAC blower motor bearing squealing) and they just proactively inspected the seal on my '23 because they said "Pretty much every explorer coming in now has this seal leaking"
Prob a good idea for folks to get under their vehicles and inspect theirs if this is the case. I actually did see the seepage but thought it was just excess oil spillage from the last oil change I gave the vehicle. Guess i was a little ignorant to the real cause.
O-ring for my '23 was part number N1MZ-4A015-C. No idea if this is the same o-ring used on the 2020's with the FADA issues. My question now is will this happen again 30-40K miles from now or if this O-ring an improved design/materials?
This video covers the o-ring
This appears to be a newish video showing how to do it on the ST by lowering the sub frame.
Finally getting ready to tackle this in the garage. Looking for the last few torque specs if anyone has them. Any help would be greatly appreciated.
Desert South West
Please see below, Instructions are for the Lincoln Aviator, scroll down to the Instillation sections for torque specs.
https://www.liaviator2.com/lincoln_aviator_removal_and_installation_engine_mount_lh-2593.html
https://www.liaviator2.com/lincoln_aviator_removal_and_installation_engine_mount_rh-2594.html
Thank you! The last torque spec for the engine mount nut can be found here with the note that its hand tools only to not damage the mount. https://www.liaviator2.com/lincoln_aviator_installation_engine-2614.html
