Did the Lincoln screen swap
Has a fix been found for this?
I don’t have this issue and didn’t “fix” anything. Just made the changes with Forscan and everything works as it should.
Acheek
2022 explorer
You were able to make the reverse and 360° camera cover the entire screen as a full fit?
Aviators don’t have a full screen back up camera. The birdseye view is on one side but there’s a button to select full screen. You just have to hit it each time.
There’s a decoder you can get for all time full screen but it’s not native.
Welcome to the forum. I'm thinking you'll have a better chance of getting responses if you will translate your Russian to English before you post.
Sankt-Peterburg
Ford Explorer
I was interested in replacing the screen, even bought it. But I want the theme of Ford on the screensaver to be.
Sankt-Peterburg
Ford Explorer
I write about a picture that appears on the screen after the machine is turned on. I saw that some forum participants also wanted to see the inscription ST.
You’re limited to the Lincoln colors and themes. I just picked a dark one. What’s weird is after the Forscan changes required it starts up with the ST splash screen but it shuts down with the Lincoln splash screen.
I posted on fmods about possibly changing the background and was told it’s not possible.
