Did the Lincoln screen swap
Has a fix been found for this?
I don’t have this issue and didn’t “fix” anything. Just made the changes with Forscan and everything works as it should.
Acheek
2022 explorer
You were able to make the reverse and 360° camera cover the entire screen as a full fit?
Aviators don’t have a full screen back up camera. The birdseye view is on one side but there’s a button to select full screen. You just have to hit it each time.
There’s a decoder you can get for all time full screen but it’s not native.
Welcome to the forum. I'm thinking you'll have a better chance of getting responses if you will translate your Russian to English before you post.
Andron78
Sankt-Peterburg
Ford Explorer
Guys, did you manage to solve the Lincoln screensaver problem?
I’m not sure I know what you mean? Can you be more specific? I don’t have anything I’d consider a problem with mine.
Andron78
Sankt-Peterburg
Ford Explorer
I was interested in replacing the screen, even bought it. But I want the theme of Ford on the screensaver to be.
Andron78
Sankt-Peterburg
Ford Explorer
I write about a picture that appears on the screen after the machine is turned on. I saw that some forum participants also wanted to see the inscription ST.
You’re limited to the Lincoln colors and themes. I just picked a dark one. What’s weird is after the Forscan changes required it starts up with the ST splash screen but it shuts down with the Lincoln splash screen.
I posted on fmods about possibly changing the background and was told it’s not possible.
4 Main Street, Wichita Kansas
If there are any Forscan experts out there, let me know if I should try something. Also how do I get a free trial again after the initial one expired
Andron78
Sankt-Peterburg
Ford Explorer
Forskan doesn't help, and the engineering menu doesn't help either. I've made an agreement with a specialist, and he's going to make a Ford update that can be installed by hacking the sinc. However, there is a problem with the saved radio stations. After a long period of inactivity, the car resets the number of preset radio stations and doesn't recognize them. I have to go into the menu, set the number of saved station tabs, and then they appear on the screen. Yesterday, I tried to solve this issue using Forskan, and we'll see if it works today.
sorry, I don’t understand. Where do you see the number of saved station tabs? Using Forescan?
Andron78
Sankt-Peterburg
Ford Explorer
Wow, I guess I need to pay for a fore scan license and check this out!
if I'm not mistaken, this can also be done in the trial version. By the way, I dug around in the evening and found another parameter that may affect this issue. The settings did not reset within an hour. I'll check in the morning and tomorrow to see if it worked.
Andron78
Sankt-Peterburg
Ford Explorer
The problem with displaying saved stations on the screen has been solved. If anyone is interested, please write to us. Forscan is required for the fix.
Mine and many others display saved stations just fine. What issue did you uncover?
Andron78
Sankt-Peterburg
Ford Explorer
Here's the only issue that I have. Can't save radio channels.
Here's the problem. The number of saved radio stations was not being saved. After starting the machine, I had to go into the settings and adjust the number of stations.
