Did the Lincoln screen swap
Catch22
Tampa, FL, USA
Quick Question for everyone that has Swapped in the 8in Vent bezel, Which part number did you use? If you go off this thread, it pulls up a different part number for the bezel trim? Sync 10" to 8" Screen (Downgrade) Upgrade | Explorer ST Forum (per this link it shows this part number for the bezel) LB5Z-99018B40-CA
But in this thread it shows this part number: LB5Z-99018B40-DA for the Bezel trim?
Before I go and buy it, can anyone that did the Aviator swap w/ the 8in vent and tray, tell me which part number they used for the bezel trim? When I looked at the picture, it seemed like the "DA" one was for the 10in Vertical/Portrait mode bezel that we already have with the Tech package on our ST?
Oh and everyone that went with the Polish guy on FB's nice mount did you use the "Trim Bezel Insert"? It looks like that is the part that goes on the back of the mount, not sure if his mount includes this piece? (LB5Z78042A82AB)
Thanks in advance for the help!! Appreciate it
bpenn8966
White Lake, MI, USA
Part number I used was - LB5B-19F648-BC searching it looks like this part number includes the actual vents, where LB5Z-99018B40-DA is only the trim, you have to swap out the vents. That's what it looks like to me anyway. Searching around it looks like LB5Z-99018B40-CA is the 8" trim, of course do your best to verify that when you order.
Catch22
Tampa, FL, USA
Awesome, thanks for such a quick reply on it!!! That makes total sense they would have two part numbers, can't believe I didn't catch that in the exploded diagram i was look at!! Thanks!
Katy, TX
I got my hands on a few more Aviator screens if anyone is interested. They do have the back cover on these, $450 shipped generally same day ordered out UPS.
Interested, sent you a DM
Katy, TX
Thanks bro!
Wisconsin
Got my screen from eBay and mounted it today with my custom fabricated parts. I ordered the lower trim piece from Etsy and it'll be here next month. Has anybody come up with the back vanity cover part number? My parts guy can't find it. He thinks it's part of the screen. I'll post pictures if anybody is interested. I switched from 10.1 portrait (factory installed) to 8" landscape and now 10.1" Lincoln Landscape.I didn't like any of them until I put the Lincoln screen in. I love this setup. Thanks to everyone who has contributed to this project.
Howdy, Did you go with the 8 inch or 10 inch screen? Can you show some photos of the final set up. I'm leaning towards the 8 inch because I dont want to cover the vent dials.
There’s no 8” Lincoln screen.
HoneyBadgerST
Cove City, NC
Has anyone had issues with Android Auto working after swap? Did the swap last night and did ForScan changes this morning, everything swapped and is working but when I hook my phone up just stays on SYNC is trying to launch Android Auto
HoneyBadgerST
Cove City, NC
Does the screen work without doing the Forscan? Is the Forscan just about the splash screens?
It turns on, but screen layout is all wrong. Tries to put the vertical screen image on a horizontal screen
Catch22
Tampa, FL, USA
Finally got all my parts in, and I swear the part number for the vent housing that attaches to the screen is identical to the portrait housing... Hopefully it isn't because it was pricey. I went off this post and the list everyone has been using. If someone could lmk what I may be missing. Didn't have time to remove the screen to compare apples to apples...
Catch22
Tampa, FL, USA
So it looks like the CA is the correct and the DA is the 10in one. That was my mistake..
I'm looking for an absolutely wrecked Aviator screen....I don't care about anything but the top 2" of the housing including the chrome trim. The rest of it can be ran over by a car for all I care. Anyone have a line on a trashed screen?
4 Main Street, Wichita Kansas
Ok boys, just installed mine, but mounted with a zip strip at the moment. I’ve got some aluminum bar stock on the way.
you really gotta manhandle the cable because the Ford screen has the connector flipped the other way (there’s a little locking tab on the port), so I had to really work it to get it connected.
but wow, it’s an awesome difference even though it’s only 2” or whatever difference. I had the 8” screen from factory. The Lincoln screen just looks better. It’s bigger and more responsive. Honestly you have to see it for yourself. It’s no Tesla screen, and all the functionality is the same, but super nicer experience.
Bridgewater, New Jersey
Does all that black part around the edges go away or no ? I thought it filled the whole screen . Is that incorrect ?
HoneyBadgerST
Cove City, NC
That black is the bezel around the screen. It's physically the same screen as the 10" vertical, so has the same amount of wasted screen around it.
