Spring Compressor
Waupun, WI, USA
Those that installed lowering springs themselves, what type of spring compressor did you use?
You need a strut spring compressor. O'Reilly has them as free rental tools. You leave a deposit until I return it but it’s free at the end.
L
Waupun, WI, USA
I'll have to check, but I'm pretty sure I've got this style from back when I had my S550. Although I never used it.
I wouldn't recommend those. get the two piece kind. They can be rented but are so cheap nowadays it is better to just buy a ser for convenience. Many have plastic storage cases too.
OEMTOOLS 27036 10.75 Inch MacPherson Strut Spring Compressor, Set of 2 Universal Spring Compressor Tool Automotive, 9.75 Inch Maximum Safe Opening, Carrying Case Included https://a.co/d/6PCYRf0
Desert South West
I've always needed 3 Strut Spring Compressors, so I bought 2 sets (4 total) from Amazon. Plus I'm not sure which set of springs I'll end up with, suspect I'll change them a few times.
L
Waupun, WI, USA
I'll probably just pick up two set from the Hazard Fraught down the road.
If an impact won’t knock it off go old school on it. Take a 3/8 drive spark plug socket, run a 1/4” extension through the hole and put a shallow 10mm socket on it. Drop the 10mm on the shaft then the spark plug socket on the nut. Hold the shaft with a ratchet on the extension then break the nut loose with a wrench on the spark plug socket. IMG_3912.jpeg IMG_3913.jpeg IMG_3914.jpeg
I’m having a hard time breaking the top nut free. Any advice?
Usually will pop off with an impact. That or spray it with penetrant overnight. Don’t know if the ST has a hex in the top or an indent on the strut tube.
4 Main Street, Wichita Kansas
Well it appears that Tammy Lynne at the ford plant took her marital woes out on my top nut. So I’ll let it soak overnight and come at it again.
Getting the strut out of the vehicle was a 5 minute job. Taking the nut off has become a 3 hour job, without success
See post #10…
Well satan’s butthole…. Unbroken did it again. But not without my mega mega cheater bar. Insane. What are these torqued to? I hope my regular ugga dugga is sufficient
I Bleed Ford Blue
23 Rapid Red Explorer ST
When I lowered my 21 I rented a spring comp, but for the 23 I just went to harbor freight and bought this
https://www.harborfreight.com/macpherson-strut-spring-compressor-set-63262.html
Also, I did as UNBROKEN suggested for the top nut, worked like a charm.
When I was putting the front struts back together, I was able to just push down on the top hat by hand enough to get the nut started, no compressor needed for the eibach front springs.
I used the same HF compressors. They worked well. But I did need to use them when installing the Steeda springs. They really don’t drop the ride that much
I Bleed Ford Blue
I had the same issue on my 21, I put steeda springs on that one and I wasn't happy with the overall ride so I went with eibach this time. After settling and alignment they are around 1.5-1.75" F and 2" R
Technically you don’t even need a spring compressor at all. Just pop the top nut off while the strut is still in the car, blow off the 2 lower bolts and lower your jack until the strut and spring fall out. Swap springs and bump stops, throw the 2 bolts back in with no nuts and raise it back into place, slap the top nut back on then drop the whole thing out to set the dust cover back into place. Doesn’t take any longer than dropping the strut and fighting with a compressor that’s generally dangerous AF anyway.
holy hell man I wish you lived next door to me.
