Spring Compressor
Waupun, WI, USA
Those that installed lowering springs themselves, what type of spring compressor did you use?
You need a strut spring compressor. O'Reilly has them as free rental tools. You leave a deposit until I return it but it’s free at the end.
L
Waupun, WI, USA
I'll have to check, but I'm pretty sure I've got this style from back when I had my S550. Although I never used it.
I wouldn't recommend those. get the two piece kind. They can be rented but are so cheap nowadays it is better to just buy a ser for convenience. Many have plastic storage cases too.
OEMTOOLS 27036 10.75 Inch MacPherson Strut Spring Compressor, Set of 2 Universal Spring Compressor Tool Automotive, 9.75 Inch Maximum Safe Opening, Carrying Case Included https://a.co/d/6PCYRf0
Desert South West
I've always needed 3 Strut Spring Compressors, so I bought 2 sets (4 total) from Amazon. Plus I'm not sure which set of springs I'll end up with, suspect I'll change them a few times.
L
Waupun, WI, USA
I'll probably just pick up two set from the Hazard Fraught down the road.
