forscan spreadsheets
Palm Beach, FL
Explorer ST 2022, Excursion 2000
Has anyone tried if the lower the side view mirrors during reverse works?
It works. Once in reverse, you just have to press either left or right mirror selector button and the respective mirror will automatically lower.
4 Main Street, Wichita Kansas
Oh ok. Interesting. When you finish parking, is there a way for it to return to the previous setting? I guess hit my memory seat button, but the driver side mirror is very buggy with that
Palm Beach, FL
It returns to the last setting automatically for me once I put it in park/drive. Interesting that it does not for you
Illinois
I wish this worded on my 25 ST.
oh I haven't enabled the setting yet. Just wanted to check on it before messing with it!
Cleveland, OH
2025 Explorer ST Vapor Blue
#27
@powerboatr @Nightshade - Any progress with the S/S disable via FORscan on the ‘25? Trying not to buy the OBD module.
#28
What does "Lincoln Experience" do for the Explorer?
#29
Just tried this. Still doesn't work.
ENable "mirror tilt in reverse". Put vehicle in R and hit left and right mirror button and nothing happens.
Rick4345
Illinois
2024 Ford Explorer St-Line
#31
I'm really trying not to be "that guy". Where did you find this at? Thanks!!!
Bridgewater, New Jersey
The easiest way to do this is u have 3 "presets" right on the door so set say #1 how u want it when u drive and then i set #3 how I want the side mirriors n seat when i back up. So when u go to back in ,stop,press#3 the mirrors will go to thet setting, so u can back in. Then when leaving press the #1 and the seat n both side mirriors will return to howvu set them for driving !
#33
That's how I ended up doing it. I couldn't get it to work through ForScan and enabling it there.
Suli
Virgina, USA
FYI, in the latest FORSCAN and following this link (https://www.macheforum.com/site/thr...-tilt-on-sideview-mirrors-with-forscan.19499/)
The mirrors on the 25' can tilt in reverse for each button when pressed.
Follow those and it works for the explorer (enable in forscan, enable in settings, first time for each side it will keep trying to move, just hit the mirror move joypad and set it to where you want).
Peteroo
Milwaukee
#35
Is anyone having a tough time finding anything FENG related in a 2023? I tried 3 seperate obd connectors and nothing as far as software or engine sound enhancement
Combatvet
#37
Just did it on my '23
In the ACM
Disabled "Engine Sound Enhancement" and "Software Engine Sound Enhancement". Threw it in Sport mode and that seemed to have done the trick.
I also turned on Software Anti-Noise Control and the three ANC microphones. WIll give this a try and see what it's like. Not necessary to shut off the FENG
TBH i'm so used to the Feng that not sure i'll leave it like this or put it back.
ESE and SESE are what need to be disabled for FENG disable
#38
Here's an obscure question.
My ST is a Canadian-spec car, that was imported into the US. SO it has a few unique things about it. Someone mentioned that the US cars have a DRL menu in the settings that allows for disabling of the DRL's while driving?
As we all know, Canadian cars all have the DRL's on all the time with no option to turn off. There is no menu.
Does anyone know if there is an option in ForScan to enable that menu again? I tried scanning through the various options but nothing jumped out at me
