forscan spreadsheets
Palm Beach, FL
Explorer ST 2022, Excursion 2000
Has anyone tried if the lower the side view mirrors during reverse works?
It works. Once in reverse, you just have to press either left or right mirror selector button and the respective mirror will automatically lower.
4 Main Street, Wichita Kansas
Oh ok. Interesting. When you finish parking, is there a way for it to return to the previous setting? I guess hit my memory seat button, but the driver side mirror is very buggy with that
Palm Beach, FL
It returns to the last setting automatically for me once I put it in park/drive. Interesting that it does not for you
Illinois
I wish this worded on my 25 ST.
oh I haven't enabled the setting yet. Just wanted to check on it before messing with it!
Cleveland, OH
2025 Explorer ST Vapor Blue
#27
@powerboatr @Nightshade - Any progress with the S/S disable via FORscan on the ‘25? Trying not to buy the OBD module.
Massachusetts
2023 ST
What does "Lincoln Experience" do for the Explorer?
Massachusetts
2023 ST
#29
Just tried this. Still doesn't work.
ENable "mirror tilt in reverse". Put vehicle in R and hit left and right mirror button and nothing happens.
Rick4345
Illinois
2024 Ford Explorer St-Line
#31
I'm really trying not to be "that guy". Where did you find this at? Thanks!!!
Bridgewater, New Jersey
The easiest way to do this is u have 3 "presets" right on the door so set say #1 how u want it when u drive and then i set #3 how I want the side mirriors n seat when i back up. So when u go to back in ,stop,press#3 the mirrors will go to thet setting, so u can back in. Then when leaving press the #1 and the seat n both side mirriors will return to howvu set them for driving !
Massachusetts
2023 ST
#33
That's how I ended up doing it. I couldn't get it to work through ForScan and enabling it there.
Suli
Virgina, USA
FYI, in the latest FORSCAN and following this link (https://www.macheforum.com/site/thr...-tilt-on-sideview-mirrors-with-forscan.19499/)
The mirrors on the 25' can tilt in reverse for each button when pressed.
Follow those and it works for the explorer (enable in forscan, enable in settings, first time for each side it will keep trying to move, just hit the mirror move joypad and set it to where you want).
Peteroo
Milwaukee
2023 ST
#35
Is anyone having a tough time finding anything FENG related in a 2023? I tried 3 seperate obd connectors and nothing as far as software or engine sound enhancement
Combatvet
Massachusetts
2023 ST
#37
On my '23 it's in the ACM
Disabled "Engine Sound Enhancement" and "Software Engine Sound Enhancement". Threw it in Sport mode and that seemed to have done the trick.
Separately, I also turned on Software Anti-Noise Control and the three ANC microphones. WIll give this a try and see what it's like. Not necessary to shut off the FENG (EDIT: doesn't work see below)
ESE and Software ESE are what need to be disabled for FENG delete
Edit. I did fine some error codes in the ACM module for the ANC microphones. Error was shorted or open. My guess is they are not present, so the ANC won't work properly if you enable it. SO i turned the ANC feature off again. No idea where the microphones are located to add them.
Interestingly enough, with only the FENG turned off i had a DTC in the APIM for "improper configuration". Everything seemed to work ok. Did a few DTC resets and key cycles and it never cleared.
Drove around a bit with the FENG off and didn't like it. I don't have an exhaust on my ST, and the V6 engine noises don't really sound that great. Ended up putting the FENG back on, which did get rid of the APIM error code.
Massachusetts
2023 ST
#38
Here's an obscure question.
My ST is a Canadian-spec car, that was imported into the US. SO it has a few unique things about it. Someone mentioned that the US cars have a DRL menu in the settings that allows for disabling of the DRL's while driving?
As we all know, Canadian cars all have the DRL's on all the time with no option to turn off. There is no menu.
Does anyone know if there is an option in ForScan to enable that menu again? I tried scanning through the various options but nothing jumped out at me
Rongold
Putnam Valley, New York
2025 Ford Explorer
#39
I see that "Global Window Close" is on the spreadsheet. How about "Global Window Open" ??? Has anyone tried it for a 2025 ??? Same settings ???
Thanks,
RON
2025 Ford Explorer
#40
Answer to my question above---I enabled BOTH Global close AND Global open---They both work. However, there are 2 more steps involved that ARE NOT on the spreadsheet. In the APIM, you should enable both global window open and global window close, and then the ability to enable & disable either one or both appear in your vehicle settings under "Windows". This is for a 2025 model year.
