Ford Performance Tune
SmittysST
SOCAL
2023 FORD Explorer ST
Where is the best place to get the FPT? I see it threw Steeda and I'm sure there isn't a Ford Dealership in Cali that would do the install....
CareerFiremanGuy
I got the tune from Lethal Performance when it was on sale.
Regarding getting it installed in Cali, it appears you're out of luck for right now.
CareerFiremanGuy
Dropped another tenth from previous best of 4.92, eighth was 8.39.
Not enough road for a full 1/4, might have to go to the track for that.
(FP Tune & AWR brace, nothing else)
Just multiply 1/8 ET x 1.56. You’ll be within a few hundredths. Should run an easy 13.0X.
CareerFiremanGuy
It should be noted the Dragy's reported temp was once again off. It was actually ~10 deg warmer so the actual DA was considerably higher than 1,100 ft.
And an 1/8 ET of 8.39 converts to a 13.10 quarter, so a 13.0 in cooler weather is virtually guaranteed.
Seeing I have no other mods but the AWR brace, this FP tune is awesome. To say I'm impressed is an understatement, worth every penny.
LA, California
Answer for my email to Ford performance regarding the same.
"First of all to the best of my knowledge they are still working on EO for 22-23.
Can I say for sure it will be approved? You never know for sure working with the government.
The 3 year 36K miles warranty is from the day the vehicle was first sold. (in service date)
After that period if something fails and is caused by the calibration there is no warranty.
If something fails and is not caused by the calibration your standard and extended would apply.
Extensive development work goes into the calibrations. We have not had any issues."
So question here would be, has anyone faced issues caused by installing a FP Tune?
My assumption is not many will raise hands for the following reasons
  1. Not many have installed FP Tune
  2. Very less time on the FP Tune, to have a failure related to it
  3. People who opt for it don't do aggressive stuff with it, on a daily basis
  4. As a relatively mild tune and developed by Ford, it takes care of other weak points in the drivetrain.
There’s a lot more than temp that factors into DA. It could actually be lower at a higher temp….gotta look at the whole picture.
20 Platinum
As always, putting wrong information out there. He has me and a ton of others on ignore since he doesnt like being wrong lol
For the new people, you CAN purchase and install it for 2020-2021 Explorer's In California. 22+ are the only ones out of luck, for now?
Treasure Coast, FL
2022 Explorer ST (AWD)
thanks for all the details. I have a very early 2020 that I bought lightly used last year, and I have the ford extended warranty through 2025 I think. Your info is directly up my alley.
I just imagine if I asked the service writer about any of this they’d look at me like I was speaking Greek and out of my mind. It’d probably be easier just to get the FP tune, though I’d have to figure out an ASE mechanic that would install it for me.
I’m just spinning my wheels. Would the tune basically give me all the shifting improvements and basic throttle improvements that the new firmware might give?
According to FP official document they claim the following: "Optimized transmission shift schedule" and "Improved throttle response throughout RPM range".
- Even though the wording is a bit (Fugazzi) some on here with the FP tune have reported tranny shift improvement. However, this does not imply a guarantee and your miles may vary.
Hope this helps.
4 Main Street, Wichita Kansas
Hope this helps.
I did install the tune in mid July, and I’ve been mostly happy with it. The power is certainly noticeable, and I think the shifting is better. I definitely can feel it hold a gear longer in normal mode during non-aggressive acceleration, and there are fewer rough shifts, but I still feel quite a bit of bucking on low gear downshifts. A tune can’t do much about whatever mechanics are at play.
I’m happy overall and don’t regret it. I wanted a minor power bump with any improved shifting, and I got it.
BigAnt75
Haslet, TX, USA
Anyone in the DFW area or Houston know of which dealership installs and offers this tune? And if so how much was the cost to install?
Xalm
Oklahoma
Ford dealer in Ardmore, OK did it for me for $48. They felt bad about charging that since all they had to do was push 2 buttons.
CareerFiremanGuy
I've raised my hand! Great info from Ford Performance BTW.(y)
Just be careful on the forum as there are a number of people who clearly demonstrate no working knowledge of anything autmotive (much less on the ST). Lol
I haven't posted more on the FP tune because typical Summer heat/humidity lends itself to high DA's and less than optimum ET's. So far, my best 0-60 mph remains at 4.8 sec, with a few 4.9's in warm/humid weather to back it up.
Again, caution about who you listen to here. Locate and block them as I did, you'll recognize them by their pompous attitudes and never ending supply of errors. o_O
CareerFiremanGuy
I did install the tune in mid July, and I’ve been mostly happy with it ... I’m happy overall and don’t regret it. I wanted a minor power bump with any improved shifting, and I got it.
Ditto! (y):)
My dealer only permits two of it's mechanics to even do that job. They registered the unit with FP, assigned me a temp password, ran the wires neatly behind the trim, mounted the tuner, and then did a test drive to make sure everything was good to go. One hour charge for labor.
Wow dude, give it a rest. The constant whining is not a good look.
It’s pretty much all he does.
I thought he had left for good…didn’t get that lucky. lol
You must have been either reading your own posts (I'm assuming you haven't blocked yourself like you have so many others) or looking in a mirror.
FORZDA3
Gloucester, VA, USA
It’s best to apply the most caution to the posts of someone who really thinks they “know” something about anything, but actually don’t know just how much they don’t know. Ignorance can be corrected with the facts, but it’s most concerning about stupid. Stupid just can’t be fixed.
Of course, I’m sure the firestarterguy also has me blocked and won’t read this post, but those that do should take note of firestarterguy’s illusions, or more accurately, delusions.
He’s 100% got me blocked…but delusions is the correct word here. lol
CareerFiremanGuy
Looks like someone I blocked is still having internet tantrums.o_O Lol
Moving on to things of actual interest to us ...
Edmunds just completed testing on two variants of the new 2024 Mustang!
The 486 hp 5.0 GT 6 speed manual ran the exact same 4.8 sec 0-60 mph as my Explorer ST did with the Ford Performance Tune.:)
