While I'm waiting for all the parts for the front GT350 brakes to arrive, I replaced the rear pads and rotors with Powerstop Z23 pads and their coated blank rotors. Yes, it's ridiculous how small these poverty-spec base ST brakes on the rear. Easy job except for a quick freak-out when I couldn't immediately get the car out of Maintenace Mode due to my inability to follow simple instructions.
After six months I finally installed my hitch cover.
Finished and installed my one-off flush mount rear wiper delete plug. 84D44D99-FDAB-4E1B-A6AC-25B24AA00803.jpeg
LA, California
Took it out on antelope valley poppy trails.
This climb was tricky. No sweat to ST though.
At the highest point.
Photos don't do justice to the real thing.
Tried trail mode and hill decent controls for the first time.
V3nom3nom
Nurse
Noticed that my Explorer doesn’t use the start/stop function?! Mine is a 2020, fault from factory? I don’t mind it off just wondering if others have noticed it off without doing anything.
It doesn't work until the engine reaches operating temp. It also won't work if the battery is low, or the oil life is low. Could it be any of those?
V3nom3nom
Nurse
Ah makes sense. Battery is from 2019, oil was just changed and drove to work this AM for approximately 30 minutes. Let’s hope the battery isn’t on its way out, just spent a grip on tires.
Jessup, MD, USA
I don't intend to upgrade the brakes, so I painted my calipers.
I have a Star White as well, and I like the blue. Unfortunately, the kids call mine the "Space Ghost", so I have to keep some red!
Toadster
Folsom, CA
Northern Indiana
Got the ST back from the mechanic today. The Thermal 2.5 exhaust was installed along with 1 and 1.25 Bora spacers with black lug nuts. Looks and sounds SO much better.
Boss240
Long Island, NY
2021 Explorer ST, 2012 Boss Mustang, 2019 Audi S4
Any pictures. Would like to see how flush the wheels are now
Northern Indiana
My photographic abilities are pretty bad, please don't judge...
Boss240
Long Island, NY
Does the front wheel pop out a little past the fender? Looks like the front sticks out a little further than the rear but it's hard for me to tell. If so maybe a couple mm smaller front spacer. Could just be the angle of the pic throwing it off a little for me.
Looks good.
I've been told putting spacers on stock ride height vehicles usually makes the gap look bigger or more pronounced. Any plans on lowering to close the gap?
Northern Indiana
I would say the front stick out about a 1/4" further than the rear, even with the staggered spacer setup. This EXST is my wife's daily driver, she'd rather have it taller than lower.
Toronto, ON, Canada
Looks good.
It does make the gap look bigger. I put on 1.5" spacers in the rear and it wasn't a good look at least imo. It made the gap look like 2 times worse.
diholf57
FORD
Washed and changed the oil.
92onward
Active Duty U.S. Navy
Washed…in the heat, outside. The worst.
Saw a lowered (magnetic grey?) ST in the VB area today. If you’re on here let me know!
