Pleasant Valley, MO, USA
Columbus, MT, USA
Thanks.........I don't expect much!! Pretty sure they will have the deer in the headlight look and be completely confused with no idea what I'm even talking about.
CPH
Long Island
2023 Explorer St
Hello, new to the forum, does this affect the 2023? Window sticker says 12-20-22
It can be done in a long weekend with a lift. Was definitely sore afterwards. Could be done in half that time having learned what I learned.
You need to look and see if yours has 1 or 2 bolts attaching the cross member to the differential. If yours has 2 bolts your in good shape. See this picture showing the 2 bolts. 1675215279273.png
CPH
Long Island
2023 Explorer St
You need to look and see if yours has 1 or 2 bolts attaching the cross member to the differential. If yours has 2 bolts your in good shape. See this picture showing the 2 bolts. View attachment 16388
OK I’m going out now to look.
CPH
Long Island
2023 Explorer St
CPH
Long Island
2023 Explorer St
So I guess they’re not going to replace this under some type of recall. That’s a little disappointing.
That's the magic question as of now. Oniy time will tell.
t
Felton, DE
AWR brace was a 40 minute total job and buys peace of mind for now. If you do it buy an E18 ratcheting box wrench. Hopefully Ford will take care of us, but not holding my breath.
CPH
Long Island
2023 Explorer St
So I read on one of the other threads, something about claiming a miss build? Is that a thing?
I haven't seen a thing about any mis-build. Do you have a link to that post?
CPH
Long Island
2023 Explorer St
OK thanks sorry about the misdirection
Thanks for the link. Interesting and if there was a stock of mislabeled subframes, it explains why we got the 3 bolt subframes for a period of time.
The other thing that is irritating about having the 3 Bolt subframe (looking at the picture of the 4 bolt subframe that Crusing68 had in his thread about swapping out the 3 bolt for a 4 bolt subframe) is that the bolt used on the 3 bolt subframe appears to be the lesser strength wise based on the bushing the bolts go through.
