Ford Performance Tune
Lake Wylie, SC, USA
For me, I'm not saying FORD's tune isn't worth it. Just that it doesn't make any sense seeing their recall and subsequent parking brake "fix".
But try telling that to some people. Otherwise, I'd be first in line to get it.
True story, my ST is currently in for rear camera blue screen (which the said is a software update, yeah ok! lol), a broken puddle light and an oil change/tire rotation. I specifically told the dealership NOT to perform the computer update recall for the parking brake and it is noted on my work order. We'll see if they listened when I pick it up this afternoon.
Socal
Yep and I find it hilarious. People waited 3 years for 30hp…for 700 bucks. lol
Warranty thats why lol To be fair, it will be a pretty big jump for older Platinum and KR owners. But then again, no one has actually dyno'd those either, for all we know, they probably always made the same power as the ST
I dunno, 30hp for $700 relatively isn’t bad. People spend more on an exhaust and I don’t think they make as much as this tune. I’m in CA so I was considering the Whipple Stage 1 but that’s freakin’ $2100(but I guess that includes the IC for that price). For $700 and not have to worry about Smog and warranty issues it seems reasonable to me. I feel this isn’t geared toward ppl who track or drag their cars regularly, more towards those who just like to put the pedal down every now and then.
Pretty positive this tune wont fly in CA. 49 state availability for MY2022 vehicles, im sure CA is the 1 state didnt approve this lol
It’s 30HP…you’re barely even gonna notice that. lol
At least im glad someone else acknowledge the older KR/Platinum isnt much, if any, different vs the ST in straight line performance.
Except it is. Less power and the difference in gearing.
Socal
35 hp isnt much more noticeable than 30hp. You'll probably notice more of a difference in lowering the tire pressure than the slight higher final gear ratio lol
We're not in the age of 5-6 speeds anymore where final gear ratios made a big difference, even then, its barely even higher. The more power you make, the less of a reason to have higher gears
San Diego
Actually this will fly in CA. It has a CARB EO# meaning it’s CARB legal, meaning it’s legal to use this in CA. I’m guessing that It won’t be available to owners in Alaska.
Socal
Seems like its only approved for 2020-2021 ST's, 22's are out of luck in CA for now?
The new Ford Performance Explorer ST performance calibration is installed using the included ProCal 4 delivery tool, and is CARB certified for 2020-2021 models, while 2022 models are legal in 49 states. Ford has determined that this calibration doesn’t adversely affect emissions when installed and used properly, but it does not have regulatory approval in California and cannot be legally registered or used on 2022 model year vehicles in that state at this time as a result.
Ford Authority Explorer ST Tune
Anyone have any info on the capabilities of the ProCal 4? Is it a repackaged SCT or other device. Can it be used for monitoring or just to deliver the tune?
San Diego
Awwww crud! The Whipple Stage 1 for awhile was only listed through 21’ as CARB legal as well. Motherlovers. Yeah now that I see it, 22’& 23’ owners will have to wait til they update it for 22’s & the 23’s.
San Diego
North Shore MA
Roseville
you car is brand new you have 4 or 5 years till smog. The whipple IC is 100% legit to use right now. I would not use there tune even if it was thrown in for free. Install the whipple get ZFG tune and in 4 or 5 years pull the tune off smog put back in and your set for 2 more years.
I think the most underappreciated part of my ZFG tune is how smooth the transmission is, especially compared to stock. Ford did an awful job programming the transmission, and I find it hard to believe they smoothed anything out in this new "tune". +30HP for $700, no thanks.
Also, did anyone notice the dyno graph compares "Base tune on 87 oct" vs "Performance tune on 93 oct"? Yeah, double no thanks.
Socal
A Bronco Raptor owner said the transmission shifted better and smoother vs the ST, both have the same transmission. Im sure Ford tweaked some stuff to make it similar to the Brapter.
Far as the graph, I mean we know damn well they dont make 400hp on 87 octane to begin with.
I can tell you right now that "graph" was created by someone plotting numbers in Excel and was not from a real dyno. 400hp rating is crank HP on a dyno test stand.
Socal
Oh im fully aware and agree. Just wanting to show a nice graph lol But still to the point, usually Ford claims are underrated on boost cars, was the same with the performance tunes on the Mustang Ecoboost and GT. Nobody had any major complaints with those and enjoyed the added power with "warranty", It will be the same case here.
However, I believe one of them had a slight high A/F ratio at least from what I recall.
I have an inquiry at Ford Performance asking if this will work for my 2021 365hp Explorer Platinum. I'll report back as soon as I here from them.
Based on the information that was provided you are better off just filling your tank with 93 octane and saving the $700.
CareerFiremanGuy
My only concern would be if there's a drive train issue they can just say "Well, you never performed the required update so we're not going to warranty your problems."
The person's statement you quoted is based in reality and common sense, it has nothing to do with "age".:rolleyes:
... Also, did anyone notice the dyno graph compares "Base tune on 87 oct" vs "Performance tune on 93 oct"? Yeah, double no thanks.
Yeah, I pointed that out two days ago in post #119.;)
The base hp on that graph is listed at 400 hp with 87 octane, that's the problem. Because Ford advertises they got the 400 hp dyno result on Premium fuel.
Going by the graph then, you get 400 hp with 87 octane and probaly 415-420 hp with premium, so the tune is only worth 10-15 hp. Very confusing ...
Yup, that's exactly what it seems like to me. I mean yes, there is some gain in hp/torque. But not a whole lot, right?
Bummer. You have the number for @ZFGracing tho, right?
The official response from Ford Performance - "it will only work on ST vehicles, it's VIN specific, so trying to use it on other editions like the Platinum will not work"
Just get a custom tune from a reputable vendor. Good news is whatever gains they claim, you can add 35 hp to that. ZFG claims a +50 hp gain on their 93 tune, so you would get +85
https://www.tunedbyzfgracing.com/
Blaster7Romeo
Western NC, USA
Not necessarily...they probably just did some of the same stuff ZFG dose in there tuning.
