Thread Starter
#61
2022 Forscan update- Finally got around to messing with it and the latest version 2.3.44 would read most of the modules, but did not identify the vehicle so I couldn't move forward. A quick email to Forscan support and they provided a test version 2.3.45 and it worked.
I was able to get into the BCM Configuration, Bambi mode and Double honk to write no issues. Then moved to ACM to disable FENG and received error messages when trying to write the changes stopping at 90%.
-Gain security access failed-security key is wrong
-Service procedure has been interupted
After disconnecting and reconnecting the changes to the Engine Noise Enhancement Software took effect and was disable however, the change made to Enhanced engine noise (or somthing like that) did not. I attempted to revert it back and it would not write it. I sent back the logs to Forscan for them to review whats going on.
For those of you having error messages I would advise to contact Forscan so they can work the bugs out of the latest version.
