NOW POSSIBLE - Amber DRL/LED bars at nighttime!
SoCal
Thanks for all your work!
Brandyn M
Pocatello, ID
Works great on my 25! Thanks again!
Phoenix, AZ, USA
Worked perfectly on my 26! I was one of the ones that had DRLs disabled from factory, once I updated that the ambers worked as DRLs. Appreciate the tutorial!
svache
Hawaii
Thanks for the write up, it worked well on my (job 3) 2025!
Just one note for those coming after me: it says "Using DRL with fog lamp” -> change to “Enable” but I didn't see an "enable/disable" option. Instead, it was "allowed/inhibited". The setting was originally "inhibited", setting it to "allowed" made it work for me.
Combatvet
So still no amber at night with the headlights on, correct?
Gadgtfreek
Mobile, Alabama
2025 Explorer ST 4WD
#26
Just ordered the OBD adapter and downloaded the SW. Gonna change to Amber next week, it just looks so much better.
Palos Hills, IL
2025 For Explorer St
#27
So I was able to to get the amber lights. However, they work only during the day and while in Drive. What am I missing here?
You can switch it to parking lights and it will display only the amber DRL (not headlights) and you can add fog lights to that by hitting the foglight button. You cannot drive at night with headlights and amber DRL at the same time.
Palos Hills, IL
#29
Parking lights turns them white. ‍
#30
I believe you have to be in a drive mode. Are you in Park? Otherwise, something didn't go as intended.
Mobile, Alabama
#31
Mine are amber in drive, off in park (daytime). White with head lights on.
Palos Hills, IL
#32
Possible. In Drive, lights on auto, amber.
In Drive, switch over to park lights, turns white.
Massachusetts
2023 ST
#33
EDIT: Answered my own question. (or rather was already answered)
#34
Great thread. Been meaning to set this up in my car. At first i was trying to avoid Amber DRL's but I see more and more vehicles with them on the road and like the look of it now.
You have a 2023? There's a separate set of instructions for 2020-2024.
Massachusetts
2023 ST
#35
Thought it said in the original post this was also confirmed working on '20-24's?
I ended up trying it as written. Made the two changes recommended and it works as described EXCEPT my white DRL bar is still dimly lit. It won't go off and leave the ambers on in any mode.
DRL is the ambers. Turns work as they should. And when the low beams come on, the white DRL bar is on like originally along with functional turn signals. ALso enabled DRL with fogs, which works.
Except the white LED bar stays lit on the lowest level. Not sure if that's how it is supposed to be.
