NOW POSSIBLE - Amber DRL/LED bars at nighttime!
SoCal
Thanks for all your work!
Brandyn M
Pocatello, ID
Works great on my 25! Thanks again!
Phoenix, AZ, USA
Worked perfectly on my 26! I was one of the ones that had DRLs disabled from factory, once I updated that the ambers worked as DRLs. Appreciate the tutorial!
svache
Hawaii
Thanks for the write up, it worked well on my (job 3) 2025!
Just one note for those coming after me: it says "Using DRL with fog lamp” -> change to “Enable” but I didn't see an "enable/disable" option. Instead, it was "allowed/inhibited". The setting was originally "inhibited", setting it to "allowed" made it work for me.
Combatvet
So still no amber at night with the headlights on, correct?
Gadgtfreek
Mobile, Alabama
2025 Explorer ST 4WD
#26
Just ordered the OBD adapter and downloaded the SW. Gonna change to Amber next week, it just looks so much better.
Palos Hills, IL
2025 For Explorer St
#27
So I was able to to get the amber lights. However, they work only during the day and while in Drive. What am I missing here?
You can switch it to parking lights and it will display only the amber DRL (not headlights) and you can add fog lights to that by hitting the foglight button. You cannot drive at night with headlights and amber DRL at the same time.
Palos Hills, IL
#29
Parking lights turns them white. ‍
#30
I believe you have to be in a drive mode. Are you in Park? Otherwise, something didn't go as intended.
Mobile, Alabama
#31
Mine are amber in drive, off in park (daytime). White with head lights on.
Palos Hills, IL
#32
Possible. In Drive, lights on auto, amber.
In Drive, switch over to park lights, turns white.
