Speaker sizes for 14 speaker system…
-REDRUM-
Omaha, NE, USA
Thread Starter #22
Okay guys… I need your help! Got everything installed and wired up but it won’t turn on? The radio says “power off” and won’t turn on. I have 12v at the LC2i and both amps… I have checked the fuses mentioned in other posts (amp fuses #115 and #127 & ACM fuse #32) and all are good. Does the LC2i need a remote in? I figured it would auto sense… Any guidance would be greatly appreciated!
You saying the oem head unit will not turn on?
-REDRUM-
Omaha, NE, USA
Thread Starter #24
It turns on but the radio doesn’t turn on… it just stays audio off.
Gotta be a loose wire somewhere imo. I assume pushing the on/off button sends a signal over the can bus to the oem amp telling it to turn on.
I used a Zen unit to tap all the channels so two plugs to plug in and the wiring from the amp was done.
#26
If your audio won't turn on in Sync, it has nothing to do with the LC2i which has auto-turn-on by default. It sounds like your ACM isn't working. Can you pull codes? Did you mess with that at all? Where did you pull you signal from?
-REDRUM-
Omaha, NE, USA
Thread Starter #27
I only have my ZFG tuner to check codes and there weren’t any that it saw. I pulled my source wires from the sub inputs and ran those to my LC2i. When I plug the power in to the controller the yellow “maximized” light will come on for a second and then turn off. I can get the “power“ light to come on if I do a 12v jumper in to the controller but the radio still does not come on? I will redo my lead wires to make sure they are correct and properly joined.
