Did the Lincoln screen swap
Here's the problem. The number of saved radio stations was not being saved. After starting the machine, I had to go into the settings and adjust the number of stations.
Any idea why it’s only some cars?
Andron78
Sankt-Peterburg
Ford Explorer
I think it's related to the initial settings of the ACM and APIM blocks. In order to display the correct number of tabs, the "Number of presets" and "Mixed mode presets" settings must be consistent. This means that the owners of the Lincoln vehicles with these screens were using a different number of tabs than the machine where the Lincoln monitor was installed. Therefore, this is not a problem but rather a matter of proper configuration.
4 Main Street, Wichita Kansas
this is very interesting. My unit came off a vehicle that was wrecked in initial transport, so I assume there were no saved channels.
Sankt-Peterburg
Ford Explorer
I don't think it matters whether you had them or not, but it's important that this setting had different meanings on your car and the broken one. You probably had several stations saved, but the new car didn't have any.
NY
Not sure if I should start a new thread, but I went to setup my Aviator screen, the orientation refused to change. I changed the APIM settings to Lincoln and Lincoln MY20 10in, and its still messed up. Its my first time using Forscan, so I'm not sure if I'm just doing something wrong. Thanks in advance
Sankt-Peterburg
Ford Explorer
Lincoln MY20 10in correct setup
Sankt-Peterburg
Ford Explorer
the values need to be changed in two lines
Bridgewater, New Jersey
Andron, or anyone else, Can you tell me the right part number for the vents so they r wider for the lincoln screen ?? Do u know the part number ?? I have searched through this and other posts and searched at ford and lasco , Finally went with marority and ordered the LB5Z 99018B40CA and it is exactly whats in my st !! Is it the LB5Z99018B40DA, Anyone know ?? I have the chrome ring on the trim. I also had a number of LB5B19F648BC which I couldnt find .. Thanks
Sankt-Peterburg
Ford Explorer
Sankt-Peterburg
Ford Explorer
Friend, I don't know what I don't know, but my screen was small. But in this thread, someone has been posting the correct part numbers for replacement since the beginning. That's for sure.
the 30 million dollar question
which vent part number is the one for the portrait to landscape 10 inch lincoln screen
So was the RIGHT part number for the swap Part # LB5B19F648BC ?? I saw at the bottom of ur post it said you have Part#:LB5Z99018B40CA .. help ?
Sankt-Peterburg
Ford Explorer
Yes, this screen is much more interesting, and it has a good resolution. I see that you have a chrome-plated frame on all sides. I couldn't find a broken Lincoln screen, so I made the missing part out of a 10-inch tablet case.
Yea I got together with a buddy at an audio shop and we added the chrome extension and made a smooth bottom for the screen. IMG_7861.jpeg
