Lowering Springs Pros and Cons
New Hampshire
So fixed the toe on the rear, again checked the camber and this is what I have with the weight off the wheels and maxed out in the slots. Not sure how you guys are getting it to -.5 in the rear for camber (without dremeling the slot) but this is the best we can do for my ride. (And yes we did the adjustments according to the info and diagram.) Not complaining though it looks good enough for me. Thanks for all the help everyone I appreciate it.
You may have one of the anomaly cars like mine that need to have the slots lengthened. I’ve seen less than 5 like that since these cars came out.
New Hampshire
Yeah kind of figured, I always have the black sheep out of all the vehicles I own it seems lol
Join the club!
New Hampshire
Danno1
CT
I have used both Steeda and H&R lowering springs on my 2021 Explorer ST. I am currently on the H&R springs. I also have the Steeda rear sway bar installed and was used with both spring sets.
I put about 8,000 miles on the Steeda combo. I have around 800 miles on the H&Rs now. While the Steeda lowering springs do not lower as much (especially noticeably in the rear) they absolutely 100% handle better than the H&Rs. They are more hardwired to the ground, and lateral handling and steering input is noticeably more crisp. With that said, the Steeda springs are noticeably stiffer, you feel bumps in the road more, but I wouldn't say it makes the ride harsh, unless you are going over pot holes or irregularities in the road, then it is more noticeably rough than the H&Rs.
The H&Rs are noticeably softer, and I noticed in comparison to the Steedas are a bit "floaty boaty" meaning the suspension isn't as responsive, or controlled and tends to float over bumps. It feels more like an SUV. The H&Rs are more comfortable, compliant and ride better especially on the highway. The floatiness I feel could probably be better managed with slightly stiffer shock valving. The Steedas have noticeably better lateral handling, but with less front end "unload" (weight transfer) during launches, which can make launching a bit more of a challenge with tire spin if you are drag racing.
With that said, I think the H&R springs are probably better for drag racing, while the Steedas would be the better choice on a road course. The H&Rs can sometimes "bottom out" (on road humps) in the rear (just have to go slower over speed bumps and road humps), there was no such issue with the Steedas, even with passengers.
Steeda Pros:
Better, more precise steering "feel"
Better turn in response, better steering feedback with road/tires
More hardwired to the ground, but not harsh ride
Better lateral handling
Feels more like a sports car than an SUV
Steeda Cons:
Ride noticeably rougher
Not as comfortable for a daily driver
Don't look as good installed since they don't lower as much as the H&Rs
Lower in the front than in the back
H&R Pros
More comfortable for daily driving, especially on the highway
Better weight transfer during launch (straight line)
Chassis looks less SUV-ish, looks BETTER
Front and rear lowering bias even
H&R Cons
Don't handle as well, more side sway despite having the Steeda sway bar.
Less precise steering input feel, less communication feedback with steering wheel to tires
Tends to feel a bit floaty boaty in comparison to the Steedas when going over bumps or imperfections. I noticed this almost immediately since I drive the same roads every day.
Rear tends to bottom out over road humps/speed bumps
Feels more like an SUV than a sporty vehicle (I'm sure it's better than the stock springs though)
Steeda side:
H&R side:
It's an old post but there is definitely a difference in the rear on both pics.
Danno1
CT
Sorry if previously mentioned. But what is Steedas REAR drop compared to factory rear?
I was going to install the Eibach's this weekend with a friend however UPS F'kd that up by not leaving the delivery even after taping (with blue painters tape) the signed ticket left prior.
It sounds like when we finally do get to the install, the simple thing to do is jack the vehicle back up and loosen the inner bolt two turns and then re-torque it. That will set the camber to near the desired number and not leave it to an alignment shop lack of knowledge?
Are any of you retorquing the rear upper control arm bolt at resting position? My thought is making this change before the new spring is installed with a rough measurement of where the vehicle will rest.
EDWYER
If a "con" exists I haven't come across it in over a year of ownership.
If you are not installing yourself, install cost can get pricey depending on who installs it. Only con I can think of so far.
Gadgtfreek
Mobile, Alabama
2025 Explorer ST 4WD
Can someone add some input? I feel this is my next mod, but I want to make sure I understand.
Most drop from least to most:
Steeda
Eibach
HR
Keeps Rake:
Steeda
Firmness (softer ride) from soft to firm:
Eibach
Steeda
HR
Thanks. I was considering Steeda just for the least drop and to keep the rake, but I feel I may go Eibach for a level look and a good ride.
H&R sitting in garage waiting for install over here.
Danno1
CT
If Eibach is considered "soft". I'd hate to feel the others, lol.
Gadgtfreek
Mobile, Alabama
LOL, it was relative. I just thought I’d read that they were the least stiff, but I assume they’re all “firm” in reality. The more I think about it, the more I feel like I don’t want the rake, so Eibach is probably my first choice at the moment. It’ll be March anyway, so I still have plenty of time to change my mind.
Loganville, Ga
Not yet Explorer ST
Don't think Steeda is most drop, pretty sure it's least. May be similar to H&R in front.
Gadgtfreek
Mobile, Alabama
Yeah, I misworded; instead of most drop least to most, it should just say drop least to most.
Gadgtfreek
Mobile, Alabama
Also had Eibach as the softest wrong too in my summary; actually, H&R. I may just keep the rake and go with Steeda. When I really get on this thing, where it be from a light, or even running 40mph, the ass already squats. Not sure I want it level.
A lot of people here, including myself, have gone from Steeda to Eibach and report only positive experiences.
Gadgtfreek
Mobile, Alabama
That's what I'm trying to figure out. What would you say, other than it being a more level look. I'd assume it handles slightly better with a lower center of gravity. Anything else? I'm old school, so Eibach is a large name to me.
As others have said, the Steeda rears almost don't look like they are lower than stock. The Steeda ride is noticeably stiffer. I and others who live up north have had issues with the finish of the springs degrading--especially the rears. It was bad enough that after three years, I purchased another set of rear springs from Steeda. I also noticed a few posters lately who said the drop on the rear springs was lower than the front--either quality control is an issues or the design changed. They were offered spacers as a solution but something isn't right there. In the end, when it comes to springs, I would trust H&R and Eibach a lot more than Steeda or Lethal.
