Global Windows Close Enable - 2025+ Explorer
Nightshade
Firefighter
Alberta, Canada
Since it's Friday, I figured, why not post this one too! Another question I got asked was, "Can Global Windows Close be enabled?" Answer is YES! The video attached shows Global Windows Close via keyfob!
**Global Windows Open should be enabled by default as standard. Check your vehicle settings on your infotainment screen in the "Windows" section. Toggle the "Global Windows Open" on!
The following will need to be changed:
1. Connect your Explorer to FORScan.
2. Go your BdyCM (easy way, not as-built way).
3. In the search bar on the top left, type in “Approach Detection” (without quotations).
4. Change the following below from Disabled to Enabled:
  • Global Close (change from Disabled to Remote)**
  • Global Close - Vehicle
  • Global Close - Initial Value
  • Global Close - Personal 1
  • Global Close - Personal 2
  • Global Close - Personal 3
  • Global Close - Personal 4
Write all to the Explorer. Cycle off, then back on.
5. Then change the following 2 modules below in "as-built" way, to enabled:
  • PDM -> 741-06-02 -> xxxx-xxx1-xx--
Write to the Explorer. Cycle off, then on.
  • DDM -> 740-06-02 -> xxxx-xxx1-xx--
6. Disconnect the Explorer from FORScan and turn off your Explorer.
GLOBAL OPEN: Click and click-hold the unlock button until your front 2 windows are rolled down.
GLOBAL CLOSE: Click and click-hold the lock button until your front 2 windows are rolled up.
--You’re done! Cheers!
Link to video for Global Close, since I am unable to upload a video to the thread: Global Windows Close - '25 Explorers
Works perfectly on 2025 Explorer Active, ST-Line, ST and Platinum!
beehandy
Central NY
Great write-up! This did not work for me at first! After completing your fifth step listed above, I had to go into the DDM & PDM(easy way) and enable global close in each.
Edit: now works as it should!
Pbmustang8248
West Virginia
I didn't have the option for even the roll down in my Infotainment system settings. I did however use Forscan and these instructions and mine is now working. Before mine didn't even roll down. I was told by one person it is due to not having a sunroof so was not enabled at factory. It is all working now. thanks
SickSix
Orlando
@Nightshade or @Pbmustang8248, can you help me with this? Mine doesn't global open or close, and I was told the same thing about not having the sunroof. I followed the steps above and in the DDM & PDM(easy way), both say enabled.
Also, has anyone figured out if global open/close can work on the rear windows too?
The rear windows do not have the Auto Up/Down feature so it will not work on them.
beehandy
Central NY
For me, it didn't work until I did both the easy way and as built way.
You'll have to go into the as-built menus and make the changes shown on post #1 in this thread.
SickSix
Orlando
Figured it out. In step 3, it says to search for “Approach Detection”, but step 4 says Global Close. I was doing multiple FORScan changes at the same time, including “Approach Detection”, so I didn't even notice the difference. When I searched for "Global" instead, I found all the settings for open and close. It now works! Thanks.
beehandy
Central NY
ah yes. If I recall correctly, Nightshade released this tutorial as well as the Approach Detection tutorial at roughly the same time. I believe that was a mistype.
@Nightshade - can you update the description in the 1st post on this thread?
SickSix
Orlando
I would also recommend updating the line "**Global Windows Open should be enabled by default as standard." That is only true if you have the sound & sun package AKA sunroof. If you don't, the option is hidden in Settings.
Ewa Beach, HI, USA
2026 Ford Explorer ST
Hey guys so it seems that I dont have PDM or DDM module or its not being listed I've already done a bunch of things on the list but I can't complete this I have a 2026 ST, any advice?
Towson, MD
I can't see PDM or DDM modules either. Is it because we have 2026 models and forscan doesn't recognize them yet? If not how do we get those modules to display so we can access them?
Putnam Valley, New York
2025 Ford Explorer
You have to do 1 more step to complete the global open/close. Go into the APIM and enable both "global window open and global window close" and then you have the option to turn either or both of them on or off in your vehicle windows settings.
