81 days at dealer for our 21 ExpST... Well crap, it needs to go back.
Massachusetts
2023 ST
That's disappointing, but not entirely unheard of. I've had similar experiences with other brand vehicles. I hate to say it, but I echo my statement in post #13.
R
rob99rt
Thornton, CO
Thread Starter #22
It's been running fine since we got it back, doesn't have any leaks, and all in all has been good to go (until I noticed that weird buzzing sound at idle). You're right, though... they've had a lot of hands on it, and after seeing the lack of due-diligence with fully completing the repair and instead them just slapping things back together, I wonder what else they left undone. At this point, if they screw it up to the point something else fails because they didn't do their job, I'm sure a lawyer would have a field day with them...
R
rob99rt
Thornton, CO
Thread Starter #23
Heard back from the dealer that they're looking for the bolts, nuts, and clips they left (or broke) off when they swapped the motors, and we should have it back tomorrow.
However... while they had it, they decided to do the 24S55 recall procedure to check the valves, even though it no longer had a motor built in 21 or 22. Apparently, they track the recall need by vehicle VIN, not an engine S/N, and the service guys didn't note it wouldn't be applicable anymore when they changed engines. That's the rev-it-for-a-long-time procedure where they sit there with it in park/neutral and run it between 4000-4500 rpms for 30-40 minutes at a time. They've now done that twice today since there were so few miles on the engine. SMH.
I asked why they were doing that when it just had a completely new motor put in it (less than 500 miles ago), and his answer was they needed to verify it was good and document they did the procedure. I fired off another email to the service manager asking why they did that when it no longer had a motor under the recall in it. I don't understand their reasoning at all...
Massachusetts
2023 ST
Unfortunately sounds like they were just checking off a box. I imagine performing the recall allows them to get paid from Ford? If that’s the case, they “performed the recall test” as an excuse to put some $$$ in their pocket regardless of the circumstances didn’t justify it.
I’d be livid.
R
rob99rt
Thornton, CO
Thread Starter #25
I’d be livid.
Yeah.... Why couldn't they have done this test on the old motor that was trashed? The recall was valid in May when they had the last, but they didn't do it then.
WHAT IN THE F@CK.. So they just abused the F@CK out of your new motor :mad::mad::mad:
R
rob99rt
Thornton, CO
Thread Starter #28
Went to the dealer to get it, but before I got the keys, I wanted to see if at least what I took pics of was fixed. Sure enough, the bracket on the charge pipe that had been pinching the wiring bundle still wasn't bolted down... So, they stole a bracket from another ExpST to get it fixed.
They had indeed done the 24S55 test on it, and while they were letting the Ford diagnostics tool do it's 55 minute test, it blew a coolant line off. So, the tech shut it down, put it on a rack and got the line back on (and checked the others), pulled vacuum on the coolant system, and filled it up again. Back again on the test to finish out the time, so that box was finally checked off.
I talked to the tech who did the valve test and he said that Ford specifies to put the vehicle outside, 30' away from other vehicles (so if it grenades it hopefully won't hurt anybody/anything), and to just let it run. He said they keep them in the bays with a 4' wide fan pushing air into the front of the vehicle to keep the coolant at a normal temp, and a tech hangs out just in case something goes badly (like a coolant line blowing off).
Anyway, drove it back and it seemed fine, but I'll be checking the overflow tank in the morning as I imagine it'll need some.
Hopefully this is FINALLY finished for a while, but I've said that before, too...
J-Dub
Buffalo NY
2021 Explorer King Ranch
#29
I just wanna know how you’re putting eight people in an explorer that can only be configured for seven people maximum?
Me 2 , I feel for Ur terrible experience But what U need is an Expedition ! Preferably a '25 King Ranch Expo
R
Thornton, CO
Thread Starter #30
Yeah... apparently I can't count. Could just have the kids draw straws and whoever gets the short one has to ride on top.
