Hate my 3" thermal exhaust
BigAnt75
Haslet, TX, USA
Just a reminder we bought a V6 Explorer not a V8 Mustang lol we all need to relax …I have the Thermal 3inch and it will never compare to my Borla on my old Mustang GT. It’s my family hauler and I like a little sound now and then …if you want to really compare get a V8 not a V6 just my opinion
The midwest
Oh, a follow up to the whole the "the stock flows fine" discussion, and that it's already high flowing, mandrel bent, etc.
It has a flapper valve in it. I was getting my old OEM ready today to try to sell it (anyone want to buy an OEM exhaust in great condition?) when I noticed a little knob looking thing. I played with it to see what it is/does.
It's literally a blocker valve thing on a spring. Like a throttle body plate. Presumably when there's enough exhaust flow, it forces the valve open. It's positioned right after the mid pipes, before the central muffler/resonator thing.
The valve closed, with a flashlight on it (it has a little hole in it):
The valve open half-way, I'm twisting it against the spring tension:
The valve just about all the way open:
There's a little ball on the opposite of this plate, it looks like a flapper valve from a toilet. This device is called an Adaptive Valve, and its job is to attenuate low frequency sound in the exhaust. It works to keep the exhaust quiet. These valves do increase backpressure, though they maker claims only a "moderate" increase.
It's worth mentioning that aftermarket exhausts, such as ones from Thermal R&D, do not have these devices in them.
That’s a very early system from the initial production run. They are all dual inlet/outlet (at the resonator, obviously) from somewhere after the beginning of ‘20.
The current quickest stock turbo ST 0-60 uses a stock cat-back. The oem exhaust isn’t a restriction for 95% of ST’s. They also stopped using that valve in 2020.
Ah, well now that is interesting. Thanks for letting me know :)
Morgan Hill California
2023 explorer st
That is the main reason I changed mine also. I realize there is a compromise with the sound. I love the sound at idle and cruising, but when you want to go fast, it is really loud. I paid $1848 shipped from Lethal, so I guess I will try it for a while. Maybe I can find a quieter mid muffler.
did you find something better or a fix for the volume? My 3 inch is way too loud as well.
Add a couple of Vibrant Ultra Quiet resonators at the end of the downpipe. It will quiet things down a bit.
2023 explorer st
anyone actually done that or are you assuming?
i rode in a 2020 with 3inch and it was much more bearable idk but mine is LOUD in first thru 4 stop n go! sounds great after that. My first thought was adding the vibrant ultra quiets or selling the system and trying the 2.5 and then back to stock with tips maybe idk but im bummed
2023 explorer st
I don’t assume. I build exhausts for fun.
would you have a recommendation for a quieter muffler to replace the rear mufflers on the thermal? Just asking thanks for your replies.
Phoenix, AZ USA
'25 Expl. ST, Rapid Red
Wow...I just read this entire thread...not EVERY word during the bickering, but most...and all of it makes me VERY happy I have a 2-1/2" Thermal exhaust system in my otherwise-stock (but for tires and wheels) '23 ST, and I LOVE the way it sounds.. Its a bit louder than stock, but it's a very attractive 'loud', and it DOES NOT DRONE.
Chicago IL
Maybe I just got used to it, but I feel like my 3'' Thermal has gotten a bit more quiet now that it has broken in after a few thousand miles. I have taken short road trips with the family (2-5 hour drives) and the kid has no problem sleeping. Even when it does get a bit loud when going 80-85 up a hill.
Comparing it to my 2.5'' Thermal I used to have on my other ST, I still think those worried about the volume should go with 2.5 Thermal.
2023 explorer st
I think they both sound similar at lower speed. This is where my problem is. I like the start up n idle and when you get on it sounds great. But it’s the fart can sound when pulling from a curb I just hate.
2023 explorer st
I
Just not sure the 2.5 would be much quieter pulling from the curb and start n stop kinda driving. At regular speed and freeway it’s great just hat 1st thru 5
2023 explorer st
I’m pretty sure mine 3inch is coming off and going for sale
but have you actually done this to an explorer with thermal 3?
Somone did it to the AWE 3" exhaust, which is volume wise the same as the Thermal. Was the "ExhaustFather" on Facebook.
i cant find it! still looking
Brian Guild is his name, and he’s on the High Performance ST group.
