In our tune, that lightly loaded area is going to be the stock borderline spark table and cylinder pressure limit no need to modify those areas tuning wise.
If he did not see knock related to your factory plugs heating up to the point where they caused knock, then the colder plugs would not show an improvement and no adjustment needed. The cold plugs are a great insurance policy however and I would absolutely install them.
I think most people can get away without plugs because most don't stay on throttle long enough. For that smaller percentage that might stay on throttle for longer periods of time a colder plug would be important.
Rev2 logs in. For S&Gs I sent Adam a log with high load, low rpm to see if he sees anything. I could not get it to demonstrate the sound I am hearing as predominately as I have heard but wanted to see if he sees any knock. This sound does not exist with the factory file so I am trying to figure it out. I will say the sound is quite a bit less with Rev2 than baseline or Rev1 so something has changed.
