I'm seeing a trend in data logs so I want to revisit the launch strategy (not the trans brake) . All new tunes have the launch strategy update. To use it do the following
-pump the brakes
-push brake pedal all the to the floor
-go directly to 100% pedal position
It's important that you don't hesitate getting that pedal to floor, there are processes that need to happen that a driven of pedal position. If you bring it up slow or don't get to 100% on the pedal you have a higher chance of spinning.
That being said the default setting when you get my tune is going to be high, pretty much as much as the brakes will hold. Right at the 3000 rpm in first and 3500 ish in second. If you need it turned down just aks for it in a change request. Also remember those second gear launches are more consistent on crappy surfaces!
https://m.youtube.com/shorts/0Y0PL4...DdblBw5w9gh-Jlb0Rs8MUU6ktj2_NTEPjlTAoUXTDTkrc
Sent from my SM-S918U1 using Tapatalk
								-pump the brakes
 - Show All
