ZFG Launch Strategy
Marinette, WI, USA
I'm seeing a trend in data logs so I want to revisit the launch strategy (not the trans brake) . All new tunes have the launch strategy update. To use it do the following
-pump the brakes
-push brake pedal all the to the floor
-go directly to 100% pedal position
It's important that you don't hesitate getting that pedal to floor, there are processes that need to happen that a driven of pedal position. If you bring it up slow or don't get to 100% on the pedal you have a higher chance of spinning.
That being said the default setting when you get my tune is going to be high, pretty much as much as the brakes will hold. Right at the 3000 rpm in first and 3500 ish in second. If you need it turned down just aks for it in a change request. Also remember those second gear launches are more consistent on crappy surfaces!
https://m.youtube.com/shorts/0Y0PL4...DdblBw5w9gh-Jlb0Rs8MUU6ktj2_NTEPjlTAoUXTDTkrc
Sent from my SM-S918U1 using Tapatalk
FORZDA3
Gloucester, VA, USA
When you say “new” tunes have the new strategy, what start date does that mean?
ZFGracing
Marinette, WI, USA
Everything after April last year.
How much to update an older tune to include the new launch strategy?
I'm not sure of today's technology by comparison but in the past, brake launching (what we used to call power braking) wreaked havoc on the converter. In fact, I had blown a front seal on the tranny. I rarely had done it so it wasn't previously abused. Are today's converters and transmissions up to the task of repeated launches in this technique?
ZFGracing
Marinette, WI, USA
Totally different ball game these days. As long as you don't over heat your transmission you're good to go. It's also the only way to launch.
Ok, thanks for your thoughts on this.
In your opinion, what would it take to overheat the transmission? I would think a prolonged uphill pull with excess weight. Launching is such a short duration it wouldn't seem like that would apply.
Pulling on a hill with the converter locked is not too bad. But an unlocked converter generates lots of heat over time.
NJ
-pump the brakes
Sorry from a laymen perspective can you explain a little more? So pump the brakes a few times and then push the brake pedal to the floor I get..but the go directly to 100% pedal position lost me. Assume that means the accelerator right? So pump brakes with left foot and then push to the floor. Then accelerator with right all the way to the floor? And that will hold the revs for launch then just let go of the brakes to go right?
I was going to start a new thread but will try here first. Seems something is not working right for me. I tried to use this feature for the first time the other night against my neighbors Durango GT and I couldn't get it to work. Either it would start to spin or if it didn't spin it would fall on it's face when I let off the brakes. I made sure the tranny was up to temp by driving to the location (about a 10-15 minute ride). We lined up the first time and I already had it in Sport (Race) Mode. I turned off the Traction Control. Pulled to the line. When he was ready I pumped the brakes three times as described and immediately pinned the accelerator to the floor. RPM's came up and it started spinning right away! I aborted that run. Second time I did the same thing and it started spinning again but we left pretty much together but he got out on me because I stumbled. I ran him down no problem but that's not what I'm getting from reading these posts and watching the videos. So I let I cool down for about 30 minutes and tried it a third time. This time I didn't hold the brakes as long and as soon as the RPM's started coming up I let off the brake and it lurched forward and then fell on it's face like I hit the brakes again! I tried it a few more time with the Traction Control on and off. I tried hitting the accelerator on the last pump of the brakes and none of it works. Also, everytime it spun the 4-WD Temporarily Disabled warning would pop up. Is it possible my tune didn't come through with this function? I got it back in August. I'm following the instructions exactly!
ZFGracing
Marinette, WI, USA
I was going to do a new thread but will try here first. Seems something is not working right for me. I tried to use this feature for the first time the other night against my neighbors Durango and I couldn't get it to work. Either it would start to spin or if it didn't spin it would fall on it's face when I let off the brakes. I made sure the tranny was up to temp by driving to the location (about a 10-15 minute ride). We lined up the first time and I already had it in Sport (Race) Mode. I turned off the Traction Control. Pulled to the line. When he was ready I pumped the brakes three times and immediately pinned the accelorator to the floor. RPM's came up and it started spinning right away! I aborted that run. Second time I did the same thing and it started spinning again but we left pretty much together but he got out on me. I ran him down no problem but that's not what I'm getting from reading these posts and watching the videos. So I let I cool down for about 30 minutes and tried it a third time. This time I didn't hold the brakes as long and as soon as the RPM's started coming up I let off the brake and it lurched forward and then fell on it's face like I hit the brakes again! I tried it a few more time with the Traction Control on and off. I tried hitting the accelerator on the last pump of the brakes and none of it works. Also, everytime it spun the 4-WD Temporarily Disabled warning would pop up. Is it possible my tune didn't come through with this function? I'm following the instructions exactly!
Send a log sounds it's just set too spicy for your traction.
Sent from my SM-S928U1 using Tapatalk
I’ll grab a couple tomorrow. We’re getting rain again today.
Ended up getting one today. Sun came out and dried everything up. Sent it in. I made sure I had the brake pedal as far down as I could push it and the tires still broke lose. I got a code P0234 Turbocharger "A" Overcharge this time so I only grabbed the one log.
