“Surging” under WOT
BoostedDadmobile
What’s up guys,
new to the platform so I’m trying to see how “normal” this is
during WOT, higher gear/speed (50+), the transmission feels as though it’s surging. Almost like an intermittent timing drop or a soft misfire. It definitely feels trans related.
i went ahead and did a trans flush/new filter to see if that made a difference, no change. Fluid was clean, no metal on the pan.
2020 w/59k, bone stock.
any thoughts?
B
BoostedDadmobile
:unsure:
Is it like a shift flare, like it’s overreving when you expect it not to? You would also feel a loss of acceleration during the shift flare if that’s what it’s doing.
There were also TSBs for the 2020 trans. Might want to make sure they were done. Might be your dime at this point, not sure. Iirc those were more for hard shifting though.
B
BoostedDadmobile
I’ve read through the various TSBs. Nothing really applies.
It’s not a flair up, it accelerates without slipping, it just… it’s like when you have a weak arm on an internally gated turbo or weak spark like the plugs aren’t gapped correctly and the fuel is washing the spark out mid combustion cycle
it’s weird.
Guess it’s time to get a tune and data log to see more stuff
