Speaker sizes for 14 speaker system…
-REDRUM-
Omaha, NE, USA
Thread Starter #42
Okay, plugged the amp back in and the radio plays. Neither amp would start off of the LC2i so I ran remote wires and both fire right up! So now to the next issue… using the sub input wires am I only limited to a bass signal? If so, what do I tap in to for a full sound spectrum? I didn’t remove the dash speaker so it plays just fine but none of the other speakers (except the subs) have any output? I’m guessing only the sub spectrum is being sent out by the factory amp and that is all I am getting to the new amps… thoughts?
I use the Zen A2B. You really need that or similar to completely change the B&O stuff. The LC2i is barely good enough to add a sub amp. It’s not even close to the right tool of the job you’re doing.
-REDRUM-
Omaha, NE, USA
Thread Starter #46
Okay thanks, never used one before… do you plug the factory wiring harnesses in to it?
Yes. It intercepts all the info, send car stuff to the car so your phone calls and bells and whistles work then gives you either optical out to a DSP or rca out to a DSP or amps.
-REDRUM-
Omaha, NE, USA
Thread Starter #48
Thanks! It’s been ordered…
