remote start not working
Edubdiz
Glenville
just triple beeps. via key fob or app. neither works. any thoughts?
21 ST
sounds like a trip to the dealer
That means it’s kicking it out cause of an error. Have you started the car lately? There’s a limit on the amount of remote starts you can do.
Hood open, door open, or been sitting for too long will all disable remote start.
Jeppo
Davidson County, NC
Battery?
E
Edubdiz
Glenville
not sure still trying to determine what's going on. Will report back
Certain pending codes will also disable it. I'd pull DTC's using ForScan (or a good scan tool) and see if anything pops up.
Illinois
Mine had a similar issue for awhile.
after a week, the shop figured it out, one of the active grill shutter fins was stuck and threw intermittent codes when trying to remote start that caused the failed remote start. They went through and cleaned the shutter, I have had no problems since.
The issues at the time were intermittent working remote start and sometimes cycling remote start 2-3 times would remedy the problem.
One of the clues that lead them to the active shutter fins was that the codes kept having to do with temp.
