Ford connectivity ?
Shepherdsville, Ky
Just purchased 2025 ST. Had no idea Ford replaced sync system. First impression, not impressed. The connectivity package is expired and I have no navigation system. Should I renew that or use waze or android auto? Really liked the sync 3 in my 2017 limited navigation system. Which direction do I need to turn to simulate the sync 3 navigation?
You still needed to pay for navigation on Sunc3. You can’t simulate Sync3 because the new system is a Google based system, it’s not even Sync4.
2022 Ford F250 Tremor
Connect your phone using Android Auto or Apple Carplay & use that for navigation. That's what I use on our 25 ST and 22 F250.
B
Shepherdsville, Ky
Tried, asks to allow Google maps to use location. Allowed that but still no luck.
Does phone need to have android auto?
B
Shepherdsville, Ky
Does it give you map on screen like sync did? That is what I am after?
Yes & yes
B
Shepherdsville, Ky
Finally got the map to show on the display. Do not like as well as sync 3. Any way to get more detailed view of Google map?
Yes, it does. If I remember correctly, it is exactly the same as what the connected version is.
B
Shepherdsville, Ky
This is what mine looks like. View attachment 35805
Do you have ford connectivity package?
I do not have that. Can't get any search results.
Signed into google account and suddenly have a suitcase and home icon on the home screen that I can get rid of.
Do you have to have the connectivity package to use google maps?
No, I don't.
MO
2026 ST AWD
bnewt,
Like a few others, I have not used Ford Connect yet. Setting your phone up as a hotspot should give you the connectivity needed. Once the hotspot is established, go to wifi (on the ST) and connect to the hotspot. The downside is you will be using data and, if you have a limited plan, you have to be careful not to exceed the limit or your carrier (e.g.--AT&T) will charge you for extra GB.
I added our house wifi to the ST and it does show as connected in the garage. I need to see if the Google maps will work (whilst on the house wifi), lol. I'll give it a try and hope - but doubt that - the saved map(s) will be available in memory. Update to follow.
B
Shepherdsville, Ky
Thread Starter #15
The past couple of days I have been able to search for destinations without the connectivity package. Hope it continues
