New fueling option for the Explorer - Port Injection
Running port injection, could be beneficial if its done in a cost effective way, and have a good way to tune it.
If done right you wouldn't need to even upgrade the HPFP, youll use the stock HPFP to control low to mid engine loads, and have the port injection come on at higher engine loads to give you plenty of head room on fueling.
Depending on the injector size, you would be able to run e85 on a stock turbo setup and keep the HPFP at I optimal operating range.
Upgraded turbo setups would be a different ball game, you might have to upgrade the HPFP atleast 1 step above stock, run 6 1300cc or maybe 6 1600cc injectors to be able to run e85..
Suprawill1
Maryland
Probably the key factor is the tuning. I've seen no tuners yet willing to support port injection. At least not the ones listed here in the forum.
I wanted to go with the upgraded fuel system (HPFP, Inj) but in my case, it definitely isn't pocket friendly. I've got the upgraded turbos and probably going to upgrade to E50 from 93DMS because the stock fuel components can handle it. Going to E85 is going to net only 25 more HP than E50 and is not worth the extra 4K+ to go that distance. E50 should take me into the 10s. I'm not tracking or hard launching so E50 would def be sufficient.
dragon434
NYC, NY, USA
Anyone on here installed one of these yet?
Suprawill1
Maryland
Not that I've heard and probably because it may be hard to find a tuner that will support that mod.
Charlotte
2021 Ford Explorer ST
I appreciate the input from everybody, but haven’t even seen OP make a comment after his initial post. Regardless I seem to be more interested than he may have been.
I also clarified from the beginning that I had zero knowledge on the topic and that I was inquiring in hopes people who understand this stuff might enlighten me and others who may be interested, and asking questions so as to learn and potentially understand a little more about how it all worked. So some replying starting off by saying something along the lines of “you seem to have a misunderstanding” is annoyingly comical because I literally stated as much in my opening sentence..
But regardless, their input (after their first sentence) is still valued and appreciated.
Correct me if I’m wrong (I guess a pointless thing to say, because I will definitely be corrected if I’m wrong) but my understanding so far based off what has been said here is that if we are not using anything other than 93 octane pump gas, then I don’t need to do a single thing to my fuel pumps or injectors. Is that what I’m hearing? Our oem injectors are that capable? My man over here saying he’s running stage 5 turbos on oem injectors is wild to me. I’m reaching the point where the only feasible “upgrade” I can make to improve power (outside of ethanol blends) is to install bigger turbos. Am I hearing that bigger injectors will not help me with that?
Second question is why would this port injection from EMS not be a good idea? It’ll clean my intake valves (from my understanding) and it will offer an increased availability of fuel to maximize my power output. (Unless it’s actually true more fuel will not help me at 93 pump gas). I actually want to hear those of you who know what you’re talking about, or even THINK you know what you are talking about, or have any experience, let us hear it so we can weigh the pros and cons (if there are any).
Third question, which is better/safer (and why)?:
Nostrum injector upgrades for our Direct Injection, or the EMS port injection. This matters, because if we can utilize a stage 1 or 2 injector for 93 octane to provide more power to those of us who have upgraded our turbos, why should we not just go the EMS port injection route? (Unless everyone is in agreement that even a stage 1 or 2 nostrum upgrade wouldn’t help either
(In no circumstance am I going to run an ethanol blend, and yes I know 93 gas has up to 10% ethanol in it, that’s irrelevant to this conversation.)
I just want to be as fast (and reliable) as possible and not use an ethanol blend, all valuable input is appreciated.
W
New Orleans, LA
Not Yet
Thread Starter #26
I went with the Nostrum Stage 3 Bundle.
Suprawill1
Maryland
Aside of the port injection scenario, you'd only need to upgrade your injectors (and fuel pump) if you're going to run higher than 50% ethanol.
As you mentioned, you're not going to do so, so your next proven option would be a tune with an FBO setup.
I myself am running stage 5 turbos with DPs, CAI, cold pipe and of course intercooler. The stock fuel system holds this combination with no problem.
As far as what I'd been told, you will run out of turbo before you outrun your stock fuel system. You'll only need to upgrade the fuel system if you're planning on E85.
According to ZFG tuning, I'm running around 600HP (540AWHP). If I decided to add ethanol, E50 will take me to around 675HP (625AWHP). (E85 = 650AWHP)
I've declined upgrading the fuel system because the HP/$ is certainly not justified. For a $4K expense, you're only getting 25AWHP worth of more ethanol.
Other than DPs, I've only included mid pipes. The exhaust is still stock. This stock exhaust system has been said to hold 700HP.
I was also interested in the port injection but was talked out of it for 2 reasons.
1) It's not street friendly
2) No tuners have stepped up to incorporate it into their tuning protocol.
For the first, you dont need to upgrade your fuel system unless you run an ethanol mix over E50. The reason why Im not a fan of the EMS port injection, is if you tune for it and it fails, it would not be good at all. For the third, theres really no use to upgrading your fuel system for 93 octane. 93 octane is a huge limiting factor, so the upgraded fuel system would have super small gains, if any.
Jessup, MD, USA
If you're not going to use an ethanol blend, it's not necessary to upgrade the fuel system. You will be octane limited even if you upgrade the HPFP, injectors, aux fuel. It sounds like PI for your use case might be overkill.
If you want to go full E85, you can upgrade the HPFP and injectors. I'm sure an auxiliary fuel system with port injectors could be a path to that too, it just hasn't been explored yet.
Do you have any E85 available? What is your hesitation to run an ethanol blend? It is pretty safe, as long as you are filling the tank properly.
As far as tuning, I'm sure most tuners can do it. Alan Jackson of edgeautosport can definitely do it. He has tuned probably thousands of Focus STs with port injection. Here's a good video about port injection:
I don't like port injection for two reasons:
1. You are adding a fuel system to your existing fuel system. More points of potential failure. I'd rather upgrade the existing components.
2. Batch fire vs. sequential fire. I don't know what fuel system controllers are available for this platform, but if it is batch fire only, it will not be as ideal.
The2ndr
Atlanta, GA
2015 Toyota Highlander
#30
I'm late to this post and don't own an ST yet, but if I had an ST I would be interested in running the distilled water injection solely for the purpose of cleaning the valves/chamber. I understand there are octane and HP limits for any oem 3.0 V6 running 93, but would only running water injection for cooling only not be desirable? I thought I read somewhere here that if just running 1 nozzle before the throttle body maybe the 2 furthest cylinders may not see the benefits? I ran water injection a long time ago on a turbo 2L 4cyl before E85 was a thing and had no issues. I know this is a totally different platform and way more engine management than my old 90's car, but just curious.
#31
If you’re just doing it for purpose of cleaning, a catch can and top tier fuel is all you need to not be getting that carbon buildup. Theres a reason why no ones really messed with water/meth injection on these cars too much.
NJ
So the million dollar question is has anyone installed this kit yet or looked into it seriously ? I'm at the point now where the stock fuel system is maxed out and looking to go full E85 max effort stock turbo setup aiming for 600+whp and this would be much cheaper than the nostrum kit. Tuning seems to be the big hang up.
#33
Still no one. Im wondering who tested it for EMS for them to release it. I assume they tested it on a ST before they released, they had to right?
NJ
That's what I'm saying. They def test fitted it to make those brackets and rails to fit and fit under the intake manifold. I reached out to Edge auto sport for info on how they do it
