Gibson exhaust
Dpratt202
Los Angeles, CA, USA
Anyone got any video clips of cruising with the Gibson exhaust installed? Aswell as interior sound clips if possible.
I want some noise from the exhaust but nothing too loud as I’m gonna daily it.
LADMarines
Active Duty U.S. Marine
Twentynine Palms, CA
2020 Explorer St
I have it, and I like it. I will do my best to get a sound clip from the phone. I mine daily, and although I wanted the thermal option, I found it to be too loud. One thing that I find strange is that at wide open throttle (WOT), it sounds like a jet engine or a leaf blower. I guess that's just the sound of the V6 turbo. The startup is nice, and the idle is cool.
As for cabin noise at highway speeds, it's slightly louder than factory—just a bit. When going up a steep hill, you do get more noise, but I enjoy it. The only downside is that my wife dislikes the modifications I've made to my Explorer. Another issue is that you need to cut your exhaust pipes at the right spot to get them to line up correctly. If you're off by just a bit, it can mess up the angle at the back. It's better to cut less than more.
LADMarines
2020 Explorer St
Sent from my SM-S908U using Tapatalk
LADMarines
2020 Explorer St
Video of start up. Ill do another one when going home today.
LADMarines
2020 Explorer St
Here is a 0 to 35. On base this is fast as I can go.
Dpratt202
Dpratt202
I think it sounds great! Like right at startup, it's loud but then quiets down fairly quickly.
Dpratt202
Dpratt202
That is just noticeable but not too loud. Thanks for making the vids!
Dpratt202
Dpratt202
I saw on Gibson's website that you cut like 1.5in from the curve etc, is that pretty accurate on how to do it?
@Cdubya has some info on the Gibson.
LADMarines
2020 Explorer St
Yes, you need to cut right where the curve straightens out. I measured three times to ensure accuracy, but I still ended up butchering the cut at an angle with the sawzall. Eventually, I got everything matched up; I just needed about half an inch more on one side. The best part, at least in my opinion, is that for the upcoming cross-country drive, I can put the factory mufflers back on with the band clamps. I have a feeling that when towing a trailer, the sound will reverberate back at the Explorer, making it quite enjoyable for a long drive.
Dpratt202
Dpratt202
Yea I like the fact that I can reinstall factory mufflers if needed.
Were you gonna use a band style exhaust clamp to attach the factory muffler if needed or how did you plan on going about that?
Dpratt202
Dpratt202
I got the exhaust installed and it didn’t take very long at all. Was a bit hesitant about making the cuts but I believe I did it in the right spot.
I did notice that slipping these mufflers over the factory exhaust tubing was quite difficult like it didn’t fit. Eventually I got them both on but I feel like the driver side tips stick out slightly more the the passenger side tips. I tried using a rubber mallet to tap the muffler on further but not sure if it was enough.
Did anyone else have that issue?
SoCal
I had a muffler shop weld mine on.
Like you, I didn't want a loud obnoxious exhaust. Gibson did not disappoint. It provides the "I'm not stock" sound and look outside, but barely any sound inside. Perfect.
I don't plan on ever changing it out, so I went with welding it on.
Dpratt202
Dpratt202
Thread Starter #14
Nice ST. Yea those tips look pretty lined up
Dpratt202
Dpratt202
Thread Starter #15
Anyone willing to share pics of their Gibson exhaust attached to the rear most exhaust hanger. I just wanna make sure I got mine lined up properly and make sure it isn’t rubbing on the metal ring
Dpratt202
Dpratt202
Thread Starter #16
Just noticed a couple things;
I do have some low end drone type noise inside the cab driving between 1.5 -2.0k rpm, not sure what could be causing it. Some research said it might be the fake engine noise causing drone style noise As stated here
second, I was adjusting one of the mufflers and noticed quite a bit of water inside here
not sure if that could also be a cause
anyway, I reached out to Gibson and awaite their response but was wondering if anyone had any insight
