The lower plastic panel, on the driver's side, has disengaged (broke) four (4) times and after each time has been replaced by the dealer. The flimsy snap-in detent at the center and front of the panel breaks and renders the panel useless, flapping against the seat frame. (This panel housed the seat controls.) Both the dealer and myself recognize a poor design that fails from simple entry and departing the unit. Needless to say, the Ford technical service engineer claims the problem has not been detected in the field and that this is a non-issue. Should this occur for the 5th time, we believe the dealer will charge me for a new reinstalled panel. Also, we believe the passenger seat will have the same issue but that has not occurred to date.
My question to the Explorer ST community is: Has any other owners encounter this seat panel breaking away from its assembly?
