Lowering Springs Pros and Cons
Green S/T
IN
Thanks. No towing for me. Have Tahoe Limited and Q7 for that
#83
You forgot Eibachs
Eibachs reputation proceeds them but they just were released so they slipped my mind.
SmittysST
SOCAL
2023 FORD Explorer ST
#84
Im looking at the Eibachs, anyone have them and can offer any pros and cons here?
Edgeybra
Los Angeles, CA, USA
#85
I just received my eibach springs today. Going to attempt to install them in my garage soon.
#86
Who did you order from? I bought it from Lethal a few weeks ago and they are on backorder until the end of the month (or so they say)!
Somalia
#88
how are the Eibachs, I want lower and the rake on my car
Somalia
#91
can springs be powder coated or does the flexing or heat involved in the process make it not work
#92
I think people have done it quite a few times.
Just installed H&R's on a new 2023 ST a few weeks ago. The rears ended up sitting about 3/4" higher than the fronts. I like a little rake. IMG_9049.JPG
#94
Just installed H&R's on a new 2023 ST a few weeks ago. The rears ended up sitting about 3/4" higher than the fronts. I like a little rake. View attachment 22879
Hopefully they settle because the rear is a little high for H&Rs. Looks great either way though.
Louisiana
I've been reading a ton of threads lately about various enhancements and I've seen more than once mention of Steeda products rusting - primarily springs and the sway bar. Does anyone know if Steeda has done anything to rectify this issue? I've seen mentioned that they have a good record of replacing parts that corrode quickly, but I'd much rather them apply a coating that doesn't rust as easily.
#96
No, there has been no change in how they cost their products.
#97
Conjecture? I noticed the springs are now coded with a date and a version. There is a slight difference in the coiling but not sure if this represents a change in design or manufacturer or normal production variation.
#98
I might be wrong here but I think that they revised the spring design.
chapel hill, nc
2021 Explorer
#99
For those that have installed the Steeda Springs, did you keep the Front Springs with the Writting upright ? Have seen on some of the install videos that others have mentioned that with other Brands they fit best when the writting was upside down on the front springs?
Plus they are a pretty blue
My old butt, thinks it's low enough. Seat is a tad below ass height so it's an easy ingress
