Cool. I'm wondering if you are lowered, should you also run shortened sway bar end links.
Thread Starter #262
It’s not required but I always do.
Thread Starter #264
Adjustable end links to get the bar ends flat like they should be instead of angled after the drop.
Canada
is being angled after the drop a deterrent inn any way to handling or performance? would you recommend adding these adjustable end links right away or wait till you guinea pig it out?
Thread Starter #266
The bar ends being angled changes the moment arm of the bar...99% of people will never notice, including me. I just want to make sure everything is as right as it can be. The adjustable links will also let me make sure there’s no preload on the bar which can also affect the handling.
Thread Starter #267
315/35/22’s square...think I will.
Thread Starter #269
I think this will be it. 325’s would need an 11” wheel imho and that’s too tight up front.
Nbk4t5e
San Antonio, TX, USA
Show off .... lol
2020 Explorer ST - Storm Trooper Build
Borla S-Type Exhaust | SPD Downpipes | Vossen HF-5 | Michelin PSS Tires | Speeda Rear Sway | Turbosmart BOV | Rear Wiper Delete | Clear Bra | Tinted Headlights | H&R Springs | Custom Carbon Fiber Steering Wheel | Custom Front and Rear Emblems | UPR Catch Can | SPD T-Stat
Thread Starter #271
Show off .... lol
Going for the Flintstones look. lol
Nbk4t5e
AWD bitches !!
Thread Starter #273
LMFAO
zdubyadubya
are those pirellies load rated for an SUV?
ur not thinking big enough. you need to go wide-body and RWB that bitch.
Thread Starter #275
Yes. They’re 111Y XL
zdubyadubya
what offset on an 11" wheel do you think would fit? 28? 25?
Canada
how about going up in size - like to a 23" wheel. 23x11 BC Forged...mmm mmm mmm!!! seriously drooling right now! LMAO! what offset do you think would work?
Thread Starter #278
I’m not gonna guess at an offset for an 11” wheel up front. Clearance would be way too tight for my liking.
zdubyadubya
If you don't mind, could you post up some pics of your wheel's clearance at full lock in both directions? or @sleekone i know you have a similar setup, could you post some on your build thread? i would be curious to see just how much room we have to work with on both the fender and the suspension bits...
Thread Starter #280
I’m out of town all week so I can’t get pics. The clearance issue with an 11” wheel and tire is at the strut...with a 10.5 +30 and 305/35/22 there’s barely 1/2-5/8” clearance there now. When I go to 315’s that will shrink to 3/8” give or take a couple MM.
