Springs installed wrong?
San Francisco, CA, USA
2020 Explorer
Dealer just installed my Steeda lowering springs, but the back is lower than the front. I strongly believe they are installed backwards. Lol
What do you guys think?
at least from the picture, the rears do seem a little lower than typical but the fronts look about right. is it possible they left out the rubber spring perches in back? I dont think its possible to install rears up front and vice versa.
Doesn’t look right. When I did mine I recall it being pretty obvious which were front and rear.
EDWYER
Take it back, it's def wrong.
M
2020 Explorer
Yea when I look at other fresh installs on here you can definitely see a rake. This picture is fresh off the install no settling. I also forgot to mention the rear has a spacer as well.
take some wheel center-to-fender measurements and compare that to what others have posted here in the forum.
M
2020 Explorer
Yea im going to try that and reach out to steeda tomorrow. I wonder if they are upside down?
EDWYER
I hope they get it fixed for you. Spacer(s) has zero effect on lowering.
Yea im going to try that and reach out to Steeda tomorrow. I wonder if they are upside down?
Not saying it is impossible to put the springs in upside-down (they would have to have really tried hard), but that should not affect the height. What I would guess is that Steeda sent you the wrong rear springs. Take a picture of the stamping on them and send that to Steeda.
4 Main Street, Wichita Kansas
how much did the dealer charge you?
