New SYNC Update 23188
My 2022 XT goes in tomorrow the issues I described above. They said there's 4.5 hours of shop time for the updates it needs. All under warranty happily...am at like 225K miles here....hopefully I;'ll have positive news to morrow- tyhey seem confident the updates they're going to apply will resolve the issues. Hopefully the APIM is OK..they thought it was last visit.
225K miles is the most I've seen posted on an ST and on a '22 no less, Must never have turned it off. :)
Seachief
Vermont, USA
2022 Stone Blue Explorer ST
WHOOPS, double-typed the second '2'. 25,967 miles. Very happily all my issues seem to be fully resolved by the upgrades they did. I haven't looked to see the SYNC and MAPS version #s, will try to add that when I get a minute. Hoping it stays stable...they made reference to the APIM having a problem during programming a # of times, but they seem to have succeeded. The APIM was not replaced (at this time anyway).
Columbus, OH, USA
25K is way less impressive.
Bpooch007
Miramar, FL
Hello All! I picked up my 23 ST in December 23, no issues with it till now, fortunately it's just the memory of the Dark version (night), and it always reverts back to a regular radio station, meaning it won't go to the Sirius station that I have programed. It won't update over my wifi as I suppose the file is too big? I don't have any black or blue screens, just those two memory issues. Running Sync 3.4....Any thoughts?
Are you on Sync 3.4 23188? That's the whole point of this thread. Go to your Sync settings and see what version you have. If it's not 23188, go to the Ford site and load up a USB stick to upgrade. Wifi upgrade may not work because of the older version messes with a number of functions.
I bet your on Sync 3.4 version 22251. Your temporary file folder gets filled up and you run out of memory. That's when all the problems you described and others start to appear. After suffering through it from April to September of last year, when the update was released... My memory problems were more than you have. I had half a map, no navigation history or favorites, radio going from Sirius to FM every time. Update downloaded and installed in less than 1 hour with a USB stick! All problems went away.
Updated mine last week
It was way beh8nd from March 2023
Then 2 days later ford owner site showed another update was ready???
The one pictured is definitely not the one you want.
I have this one now
D8d the USB stick to update
What I am confused about..is explorer sees and connects to my home wifi...auto updates enabled.. it will search for updates.
But not find or do any.
So I used the USB download.
Very strange..my 21 f250 sync 3 did downloads all the time
My now f150 sync4 does them as well
Cape Girardeau MO
Ill have to do this when I get home
D
Thread Starter #192
I have this one now
I have never had any luck doing a OTA update with mine. I don't even try any more.
I have had pretty good luck do far ..except in the explorer
Beginning to winder if tye 4g lte wifi hot spot delete is the issue
San Francisco
This is a write-to-tmp-folder-without-cleanup issue?
UGH. Bad engineering bugs me.
Why are you releasing images with debug messaging, lack of a cleanup process, etc?
Honestly, /tmp is temporary. You should write nothing there that is not going to be deleted after the car turns off, and it should empty at shutdown or startup. :geek:
