Focal, Mosconi, Illusion and Helix build
Thread Starter #121
For things I put together with exposed hardware I always use taper head titanium…so I had to order bolts for the subs and tweeters. I’ll have to turn the heads myself for the sub bolts…I could only find parallel head.
B337A033-B2D4-4EDA-AA4D-125AB857418D.jpeg B337A033-B2D4-4EDA-AA4D-125AB857418D.jpeg
Of course you went titanium. Just think about the weight savings from those fasteners :LOL:
Thread Starter #123
3 layers of chop mat…so much fun.
Thread Starter #125
Time to milkshake the back side and filler tomorrow.
Nbk4t5e
San Antonio, TX, USA
Looks good man. Perfect time to do a CF overlay.
Thread Starter #127
Finished up the wiring with Techflex today too. DF753B11-65D5-42B1-9431-11020EF72CEB.jpeg
Thread Starter #128
Guide coat is on…final sanding this week then texture coat and paint. Using all SEM products.
Thread Starter #130
Buttoning up the doors today. Now for break in and tuning FF132A8D-A5A8-426E-B757-B77535246980.jpeg 7E9BA944-80A5-4324-932D-0E565BF0D1E5.jpeg C0495C77-D90F-4DDA-881F-DC8760FD6FCD.jpeg 96F13812-D678-4248-B02D-3537DB286BFE.jpeg
Man those mounts look FANTASTIC! Looks like it could be stock. Nice work! I'm glad my sub box will be hidden behind a panel as my finish skills are not up to par.
Salem, OR, USA
I really need to drive to Texas and learn from the expert!
What did you use to get that mild "pebbled" look?
Thread Starter #134
SEM texture spray. Videos make it look easy…I disagree. lol
I had to retexture the whole piece to get it to match. Even holding the can 24” away it was still heavy.
Chaseg08
Golden, CO, USA
I did not see you mention where your remote turn on comes from for your amps. Would mind telling me? I'm hoping to pull from the factory amp but I'm not sure which wire it is.
Thread Starter #136
I ran a switched 12V wire from the dash back to a relay…that turned on the DSP then the remote wires come off the DSP.
Thread Starter #137
Better pic with the door closed.
Thread Starter #138
You've got mad skills there! I'm embarrassed when I look at my sub enclosure :)
Thread Starter #140
