The older first generation edge used the larger 5x4.5" or 113.4mm lug pattern just like our current explorer does. Anyway I really like the look of these wheels, and from what Info I found they have a 63.4 mm hub bore and are 22x9 with a 39mm offset
https://www.detroitwheelandtire.com...ement-3850-polished-black-hol-3850-pbp-a.html
The standard 20's that come on the ST also have a 63.4mm hub bore and are 20x8.5 with a 44mm offset
https://www.detroitwheelandtire.com...ory-oem-used-replacement-hol-10270-mbm-a.html
The only issue that I can think of is the lug holes might need to be opened up a little as the first gen edge used 1/2" wheel studs, and the 20+ explorers use a larger 14mm wheel stud.
