it should be 8mm, I used a deep socket. 10mm is for the filter housing nut. i literally just finished changing mine like 2 hrs ago. make sure it is seated properly, you need to press it in a little at all 3 points, then press in the bottom bolt by hand and start turning it; it eventually starts threading and then use the 8mm socket.
