2021 ST BOV
Fairmont, WV, USA
Sorry for the “noob” question! Looking to upgrade the BOV in my 2021 ST but it doesn’t seem to be in the same position as the videos I’ve watched pertaining to the 2020’s. Any pictures or help would be appreciated!
It’s in the same place. Left hand side below the air box.
SBF445
Courtland, MN, USA
I picked up my infinite blue ST today and no blow off valve under air box. There is a provision in charge pipe where one would be.
Selldawg22
Fairmont, WV, USA
I’ve removed the entire air box and everything around it; no BOV ‍♂️
Selldawg22
Fairmont, WV, USA
I got mine Monday, pulled everything out today and found nothing ‍♂️
CA
Yours is not here? It's easy to miss. You can see mine with a red VTA adapter on it.
Sent from my SM-G991W using Tapatalk
Yes his is right there. He just doesn’t know what he’s looking for. Your pics should clear it up.
Selldawg22
Fairmont, WV, USA
Thanks for the reply! I’m not a car “noob” just newer to the explorer scene. It is 100% not there. I believe it’s been relocated further down on the left, in a much harder-to-reach area. I’ll get some pics tomorrow, maybe you all can see something I’m not.
Selldawg22
Fairmont, WV, USA
Loosen your tampon, just a guy asking for help. Appreciate the feedback :poop::poop:
You’re asking for help and ignoring the help you’ve been given. Nothing changed and nothing moved. The bypass valve is still in the same place and still connects to the driver side turbo inlet tube just like it has since day 1. If you’re looking for a BOV you won’t find one…because there isn’t one.
SBF445
Courtland, MN, USA
SBF445
Courtland, MN, USA
There is a provision for it in the tube but no bypass valve
Selldawg22
Fairmont, WV, USA
Thread Starter #15
You’re asking for help and ignoring the help you’ve been given. Nothing changed and nothing moved. The bypass valve is still in the same place and still connects to the driver side turbo inlet tube just like it has since day 1. If you’re looking for a BOV you won’t find one…because there isn’t one.[/QUOTE
Sure thing buddy!
Look closely at post #8.
Selldawg22
Fairmont, WV, USA
Thread Starter #17
Thanks buddy. I do appreciate your help! I’m going to snap a few pictures this evening when I get off work. I’ll take everything back out and hopefully we can solve this scooby-doo mystery.
Again, nothing has moved. Look here. Red arrow is the grommet the airbox snaps into. Yellow arrow is the T fitting on the coolant hose. Red circle is what you’re looking for.
Different angle, same markings. Turbosmart BOV being installed on a ‘21.
