Forscan settings discussion
Canada
#41
How about the Enhanced exhaust noise or piped in fake engine sound on the ST in sport mode? Has anyone disabled that yet or know how to do it?
I’ve test driven one and that’s the best one I’ve heard from ford. The one in the fusion sport is just trash, the mustang eb is also trash. Still I’d turn it off also.
kartman
AZ
#42
This, fake engine noise is terrible.
GBVx
Washington D.C., DC, USA
#43
Just FYI, A lot of the things addressed in this thread have been discussed, and mostly fixed over on explorerforum.com
Canada
#44
Take a fusion sport for a test drive in sport. You’ll love the one in the explorer
Decoynj66
Maple Shade Township, NJ, USA
#48
Are you sure? Pretty sure that turns all alerts volume to zero...
It's the same setting for F-150. I found multiple people said thats the setting.. I turned it off on mine. Not sure what alerts your asking about?
Philadelphia
Turn off fake engine noise in Forscan.....It's under ASM....change the 4 to 0
Confirming that this worked. My cabin is eerily silent until I get my exhaust work done next week.
LokiWolf
Henrico, VA
#50
But did it turn all alerts down? Including parking?
Jacksonville, FL, USA
#51
i can confirm that parking alerts still work after disabling augmented Vroom Vroom sound. It's now pleasantly quiet but when you get on it, it's got a bit of a supercharger whine (music to my ears) which was never audible before i disabled the fake crap. I can also hear the blow off from my VTA BOV adapter nicely too.
LokiWolf
Henrico, VA
#52
Good stuff! Gonna make the change then! Thanks!
#53
Has anyone heard of a way to do any of the following via FORScan:
  • Utilize the full screen for camera views (and not just the top half)
  • Enable front camera at any speed (disable speed-limiting component)
  • Show temperatures on gauges
  • Show battery voltage
  • Disable no hands on wheel alert for intelli cruise/wheel centering
  • Remember your pre-collision settings even after key cycle (truck always defaults to all on for pre-collision settings)
Philadelphia
The camera view is a UI problem. I bet a Sync redesign update would be required.
I’ll jump back in and check for the rest. FORScan is so archaic its painful to use.
LokiWolf
Henrico, VA
#56
Nope.
None of those are doable on ours at this moment...
Front camera should be in theory doable, but finding then coding would be the challenge.
#58
That's a typo. It's actually ACM. And set the number to 9 instead of 0, because 0 will disable your center dash speaker.
i saw a DTC related to speaker and i'm betting this will be fixed by changing the 0 to a 9 as you suggested. Gunna try it tn
