FORD dealer says the NGK cold plugs from ZFG now means I need a long block in my 25!
St. Louis
Agreed, we need updates. Respectfully requesting.
Z
SC
Thread Starter #23
My apologies guys in a crunch for time right now, but I finally have a Ford determination so far but I still have to talk with them personally I just got the word they are saying they will not cover it so there’s a little bit more discussion to do before I will probably end up going ahead with the repair on me. It sounds like if nothing changes I report the conditions mañana sorry for all the delay. Just waiting for things to happen right now. The car is at the dealer in the garage and the motor is out, let me give more details tomorrow just for information again they were tuner gapped .028. Installed by the dealer. That’s pretty much the basic grill for the moment unless something I can change which I’ll find out tomorrow better after talking with FORD (not the dealer) and a few other people.
Z
SC
Thread Starter #24
They’ve had me on a loaner truck this whole time full-size 4 x 4 four-door no cost …one good thing o.
MO
2026 ST AWD
Zorrosdens,
Sorry to hear that you may be on the hook for the repair. I sure hope there is a post-mortem to provide a root cause. I can't see how sparkplugs could cause engine failure unless one disintegrated into the cylinder. If one popped out, would that not be due to installation? The dealer technician installed them so workmanship should not be on you other than the labor for the original work.
/edit/
I forgot to mention that you should ask for copies of any boresope photos or videos, if available. There's got to be something lurking in a cylinder or two.
end of edit/
Hopefully, Ford will look after you (financially) for the engine work. Best wishes on the path forward.
ADHeimke
PHX, AZ
2026 ST
#27
Sorry, not trying to be rude, but can you explain exactly what the issue or damage is such that dealer says you need to replace the long block, i.e., the major mechanical part of the engine?
Misfires can come from a bunch of different causes, from as simple as either the coil pack not being fully seated onto the plug or the connector plug to the coil pack not being connected properly, to various ECU issues. I have a ZFG 91+ Performance tune, and I haven’t changed plugs, didn’t see it as a requirement or recommendation on their site, but I do no see where they list them, which I hadn’t seen before.
Even if someone cross threaded and forced one of more of the spark plugs into the head, all you would need is repair or replacement of the head(s). Now, if in doing that the plug was damaged or broken such that part of the plug end up falling into the cylinder, ok, that would destroy things, but you would have felt and heard that immediately once you started it.
A tune would have to be pretty extreme and have been run hard for a long time, barring a manufacturing defect in the engine, to do any damage from, for example, over fueling or overheating it. If something wasn’t built correctly at the factory or was out of spec, ok, running a tune and putting extra stress on the engine could cause that damage to be seen soon sooner than without the tune, but that doesn’t sound like it is what you are saying…
Can you please provide details as to what exactly was damaged and anything you know about how it happened? Just (properly) installing spark plugs isn’t going to destroy an engine such that a “long block” requires replacement. It might run like crap, but “wrong” plugs won’t break anything.
IL
2024 explorer st
I put those plugs in.( Had data logs on stock motor) data log after plug change wfo. No way would i run that plug in a stock engine especially on 87. Its a projected tip plug requires less ign adv.
It idled better, ran better around town with those plugs. Didn't like wfo with a stock tune. It running better around town is a clue combustion is better. So more likely, its to much at wfo with a STOCK tune.
No way would I run them on a stock tune. I pulled them out when I had a stock tune because I saw what was coming on the data log.
Tuned that's totally different.
Don't believe me. Data log it see for yourself. Maybe ok on 93 cant say, Didn't test that
Projected tip plugs have always required different ign timing since the beginning of time.
#29
Factory plug.
IL
2024 explorer st
#32
If damage is cause from detno. The customer should have to pay. Not fords fault. Blunt truth.
#34
So, in a nutshell, installing plugs made for tune without the tune = melted pistons?
A colder plug may result in a rougher idle but I have never heard of or experienced a colder plug doing anything detrimental to the engine tuned or not.
#35
I am having a hard time following your posts and the acronyms used. Can you please explain how a colder plug would cause an issue with a factory tune? You mention "WFO"? and "DETNO"?
Both plugs have projected tips.
IL
2024 explorer st
#36
The ngk has a projected tip, it sits out father. This changes the flame front. Doesn't matter if its colder. What matters is how it acts.
Detno = detonation.
Engines worst enemy.
Wfo= wide f@!king open
You know ford has there own recommend colder plug. Doesn't look anything like ngk.
You know fords combustion engineers have a phd? All oems do.
I am not a average st guy . I did use to test this stuff in a different life.
#37
Detno = detonation.
Ok got it. Interesting this 3.0 is so finicky over a plug. You mentioned 87 but 91 or 93 with a colder plug and a factory tune is an issue?
