2025 Oil Capacity
#81
Hi everyone…hoping nobody yells at me for this…seems like a topic with a lot of friction involved. I’m relatively new to the forum and to my 22 ExST. Previous vehicle was a ‘17 Focus ST, so I’m not a stranger to EcoBoost engines. The Focus just didn’t have any oil pressure issues on launch. My ExST is pretty much just a grocery getter with the occasional fun off green lights…nothing crazy. But I thought I saw somewhere in all the threads that even in stock form with normal “spirited driving” there can still be an issue with potential oil starvation under hard acceleration?? Would it be beneficial to use the 6.5qts in my car or overkill?
I pulled 6.44 qts out of my 2025 factory fill with 1k on the odo. I refilled with 6.5 qts. This took the dip stick to between the top hash and the top hole after a 12-15 min wait.
Mobile, Alabama
2025 Explorer ST 4WD
#82
Another interesting test, I think, would be UOA's. If your oil level and driving habits are causing starvation, would you not see an increase in the wear material from the bearing? I just sent in my first analysis, and will be doing several more as the motor gets some miles.
stumpy86
northern ill
24' explorer st
#83
Overfilling these engines by 1/2 qt to 1 qt wont hurt them. Like may others have said if you run 6 qt factory fill and launch and drive it hard the oil pressure does drop and over time it will smoke the bearings. I personally run 7qts in both mine and my wife's ST and have yet to have a problem
Dominican Republic
Ford Explorer ST 2021
#84
7 qt here too
Lubbock texas
2021 ST carbonized grey metallic w/black leather
#85
Yeah we're probably splitting hairs.
But at the end of the day, you can either follow your owner's manual, or what someone tells you on the internet.
ohh and i'm not capable of learning from someone who has way more know that my tiny brain is capable of ever holding on to JUST SAYIN Steiner. try to have an open mind you learn more in life that way
Mobile, Alabama
#86
For anyone who is bored. Shop service fill from yesterday, vs me adding a 1/2 qt this morning. The engine sat all night.
#87
Mobile, Alabama
#88
Thats where it sat after the factory fill dump and refill after I added a 1/2 qt last time. Never budged for 5300 miles.
Nunya
For folks who datalog, what is the typical oil pressure drop on a launch? I did 6.5 qts on my last fill (2020 st) but still seeing 18.9 psi dip around 20mph. This is from a boosted launch running 4.6s 0-60. Wondering if this is worth adding another half quart or if this is just inevitable. Max PSI my datalogs capture is 37psi, is that the sensor max? Seems low still.
#90
Interesting. So it appears a delay in pressure drop after the launch but before the first gear shift? Would make sense, pick up full at launch, slosh then lower pressure before back to pressure before the first gear change. 18psi is not great. I think someone has done 7qts but I am not sure if crank case pressures increase or if oil aeration is an issue with the 3.0 Ecoboost at 7qts (still new to the platform).
Mobile, Alabama
#91
Neat. Thanks for real data. Im adding a 1/2 qt after each change, but also not doing hard launches. Was just precautionary.
Nunya
Today I added half a qt to get the oil level closer to the bend on the stick. Then I did a faster 4.3 sec 0-60, and the oil pressure only dropped to 32psi.
This has been discussed over and over but it is cool to see the proof on the screen. Half a quart could really make or break. And important to check often because these do consume a good bit over time.
ARC
Oak Lawn, IL, USA
2022 ST Black
#93
I learned the hard way and spun 2 rod bearings from having the oil too low. I used to go 5k between changes, but not anymore. Going forward Im only running 6.5 qts on the new 2026 I ordered.
#94
Were you running 6qts on the old one?
#95
You going to run 7 qts moving forward?
Nunya
Not too sure, i put 6.5 qts in about 3,500 mi ago so I’m guessing i just consumed half a qt. When i added the half qt I’m guessing it brought it back up to 6.5 qts.
When i do my oil change in the next week or two i’ll measure it since i use an extractor and see where i’m at.
#97
So when you dropped to 18psi you’re not sure the amount in the sump?
Nunya
Correct. On the dipstick the level was at the top hole but from my memory 6.5qts sits higher than that
Nunya
ok got it. So 6.5qts runs 32psi.
I’m just estimating it’s at 6.5. Also, i’m at 6,000ft elevation. People with my setup and tune at sea level are running high 3 sec 0-60s so it could dip lower for those folks.
