2025 Tuning
Fort Lauderdale, FL, USA
Looking to get back into a new ST, I wanted to see what has changed in terms of how you tune them? Can I use an SCT tuner still?
Yes but it has to be the BDX. Not the best device to be using though, HPTuners is worlds bettter
SoCal
Be advised, as of today, Cobb doesn't tune 2025+ ST's
BLucas86
Good to know - I had used the GearHead AO tube previously. If I get the SCT BDX can I still use that tune? For the price I think it’s probably the best. But could be wrong.
If double the price I can go ZFG, he does have 2025+ listed on his site. But curious the other options
BLucas86
How does Livernois compare to ZFG. Says +100hp & 115tq… ZFG about the same but double the price.
Is ZFG worth double the price if money is a concern? I could use that extra money towards an intercooler or intake if it’s about the same..
You can’t use the same tune, no.
You keep saying ZFG is double the price but I don’t see that anywhere. It’s only about $280 bucks more and you get a better tuning device.
Mobile, Alabama
2025 Explorer ST 4WD
Have used Lund, PBD, Livernois and ZFG on different Fords. Been really impressed with ZFG.
BLucas86
Livernois is $699 & ZFG showed close to $1200
Well ones $500 & ones $979. That’s basically double?
The Livernois is $700 and the basic ZFG tune that is comparable to Livernois is $970. The $1200 option is the DMS option, which is something I’d recommend but it is on a different level then Livernois.
BLucas86
Ah I see, you are correct I was looking at the 2021-2024. I do see now that the Livernois 2025 tune is $100 more @ $699.
So I guess is ZFG worth the extra $300?
Or is there a place to get a tuning device cheaper for the ZFG tune?
For the device alone I say yes. Can’t really find it much cheaper since you have to get credits anyway.
Louisville
2025 Ford Explorer St
Are you guys logging knock and load with those pulls?
A lot of these timing differences between 91/93/E30 can look fine until you actually see knock behavior and load together.
Without that, it’s hard to tell if it’s clean timing or just not showing the full picture.”
Louisville
A lot of what you’re describing sounds like people jumping ahead of what the data is actually telling them.
Before even worrying about which tune or numbers, you want to make sure the logs are complete and consistent. If you’re missing things like AFR/Lambda, knock activity, or load/throttle in the same pull, it’s really easy to misread what’s going on.
A lot of “good” or “bad” results people talk about come down to incomplete data or inconsistent logging more than the tune itself.
If you haven’t already, I’d focus on getting a clean, repeatable log with all the key channels first, then evaluate from there.
Sounds like the same thing you said about tuning the stereo.
